Sponsored by: Auxito
help No headlights?
Old Dec 16, 2013 | 08:48 PM
ravens fan's Avatar
ravens fan
help No headlights?
Hey guys my dad has a 98 f150 with 188,000 miles, about a week ago the driver side headlight went out we replaced it but soon noticed we were back to 1 headlight were not sure which one burnt out (we think it was the passenger side one) but now there is no headlights working on low beams and one working on high beams the one working is the driver side
any one have any ideas?
we checked the relays and fuses and all seem to be good
thanks!
Old Dec 21, 2013 | 08:06 PM
Cristolize's Avatar
Cristolize
Replace the light switch inside the cab that runs them sounds like the tumblers are worn/wearing which is causing electrical surges/grounds that should not occur under normal operation. Also check the grounds to the headlights as i believe in those years they were grounded to the cab/frame and not a dedicated ground through the harness.
Old Dec 21, 2013 | 11:20 PM
steve(ill)'s Avatar
steve(ill)
Had a van once that had bad fenderwell plastic - tires thru water / snow at the back of the bulbs and caused short life... See if you have voltage at the bulb socket before you start replacing switch.
$ledgehammer
Aug 26, 2017 11:51 AM
adamg101
Nov 7, 2007 10:38 PM
MICBAR
Nov 30, 2005 07:57 PM
grafekie
1997 - 2003 F150
Nov 5, 2004 06:34 PM
torquemeister
13
Jan 30, 2004 11:59 AM
