Best Header Gaskets
Old Dec 16, 2013 | 08:03 PM
CS45's Avatar
CS45
Best Header Gaskets
I am looking to replace my header gaskets as the left one blew out recently. I asked my muffler shop (who I trust and who installed the below exhaust system) if there is anything better than what came with my stainless Ford Racing Headers and he is looking into aluminum something or the other, and if my heads have round or square ports.
Any feedback or suggestions would be welcome.
Stock 351W with 195,000 MILES
Stainless Shorty Ford Racing Headers with 2.5 in custom mandrel bent Y-pipe into a straight flow cat, Flowmaster and 2.5 single out behind left rear wheel.
Also help with the type of port is welcome.
Thanks
CS45
Old Dec 16, 2013 | 08:07 PM
JWC 3's Avatar
JWC 3
I use to like the copper metal looking ones , Mr Gasket I think makes them . I had better luck with them . Haven't had headers for years though..... Just a thought !
Old Dec 16, 2013 | 08:38 PM
Nickk97tml's Avatar
Nickk97tml
Your heads have square ports. I just ordered a set of JBA headers and mine came with plasticky/rubbery ones and I think they aren't that good (I know next to nothing when it comes to gaskets). Im also Interested to see whats the best gasket for headers.
These are what they look like:
Front
Back
Old Dec 16, 2013 | 08:46 PM
Diesel_Brad's Avatar
Diesel_Brad
The best gasket is NO GASKET.
But since your flanges are so thin you have to run them. Any gasket is good, but the bolts are what make the difference. They need to stay TIGHT. Looking in to some stage 8 locking bolts
Old Dec 16, 2013 | 09:05 PM
Nickk97tml's Avatar
Nickk97tml
These? Proform Wedge Locking Header Bolts 1"
Old Dec 17, 2013 | 08:00 AM
White Max's Avatar
White Max
Originally Posted by Nickk97tml
These (though be sure to choose the correct length for your application): http://www.summitracing.com/parts/stg-8933/overview/
It also actually helps to spread a very thin coat of ultra-copper rtv on both sides of the gasket right before installation.
Old Dec 17, 2013 | 08:14 AM
Freightrain's Avatar
Freightrain
I used the generic paper ones that came with my pacesetters and they work great(on my 2nd year). I tightened them slowly and evenly and made sure they were tight all the way around after a couple heat cycles. These headers have very thick flanges(5/16"?) so I think that helps.
Old Dec 17, 2013 | 10:56 AM
Diesel_Brad
World's Best Locking Fasteners & Locking Nuts and Bolts STAGE 8
Old Dec 17, 2013 | 01:43 PM
boonslick's Avatar
boonslick
Header Gaskets
[QUOTE=CS45;13850902]I am looking to replace my header gaskets as the left one blew out recently. I asked my muffler shop (who I trust and who installed the below exhaust system) if there is anything better than what came with my stainless Ford Racing Headers and he is looking into aluminum something or the other, and if my heads have round or square ports.
Hello and good afternoon.
Percy's Header Gaskets was recommended to me so I bought the Carbon XX 2000 Degree set. The ports are square.
I also bought ARP bolts. Both are available at www.summitracing.com
You will also need Grade 8 Collector Bolts, nuts and lock washers which I purchased at NAPA. I purchased 7/16" X 14 NC X 2 1/2" long.
Take care.
Boon
These recommendations are all from the forum users so I just went with them.
Old Dec 21, 2013 | 09:21 AM
CS45's Avatar
CS45
Thanks everyone. I already have the high speed bolts and lock washers installed when I had the headers initially installed. I went with Fel-Pro gaskets originally but they blew out after 2.5 or so years.
I am going with Copper crush gaskets that my exhaust man found after some internet research. I'll let you know end results.
CS45
Old Dec 21, 2013 | 10:22 AM
JWC 3's Avatar
JWC 3
I think you will have good results with the copper ones . I have run them on many vehicles . I always had good luck with them . Best of luck !
steuben
Nov 28, 2008 10:25 PM
jowilker
26
Oct 13, 2007 06:02 AM
scamardo
21
Feb 18, 2006 05:41 PM
imlowr2
Sep 24, 2004 11:37 AM
forddytube
Aftermarket Products
Sep 19, 2003 10:53 PM
