Frame swap....differences
Old Dec 17, 2013 | 08:32 PM
Diesel_Brad's Avatar
Diesel_Brad
Crossmemember is NOT the same. The gasser one has a HUGE hole in it for the oil filter. The diesel one does NOT. But YES, perches can be swapped but drivers side will only have 3 bolts holding it instead of the original 4
Post 34 shows the difference
https://www.ford-trucks.com/forums/9...started-3.html
Old Dec 19, 2013 | 11:53 AM
96ford250's Avatar
96ford250
No they are not there is a hole where the oil filter comes out for the gas truck. You will be missing one bolt on the driver side engine mount take it from someone who has done the swap.
Old Dec 19, 2013 | 12:45 PM
DIYMechanic's Avatar
DIYMechanic
My mistake guys, what I meant to say was that the gas support can be used for the swap. I guess they're technically not "the same", but they can be used.
Old Dec 19, 2013 | 06:03 PM
ReBilld's Avatar
ReBilld
The 460 gas cross members are identical to the 7.3 cross member. Has the exact same holes and all four bolts on the driver side mount will bolt up. The 5.8 cross member is the one with the large hole for the oil filter.
Old Dec 19, 2013 | 07:53 PM
Diesel_Brad
My 460 frameS have the same exact hole as a 5.8 frame
Old Dec 19, 2013 | 09:14 PM
ReBilld's Avatar
ReBilld
IDK. I've got two 460 truck frames and two PSDs out there and they look the same. All four bolt holes for the driver side PSD motor mount are there on the 460 frames. I didn't unbolt the driver side motor mount on the PSD and look under it, but the both the 460 frames have the smaller holes like the PSD. Neither of them have the large hole for the oil filter.
Old Dec 20, 2013 | 06:26 AM
Diesel_Brad
I have 3 460 frames. All have the large hole in the crossmember
Old Dec 20, 2013 | 07:37 AM
madpogue's Avatar
madpogue
Wonder if it's a function of where the truck was built, or what supply of cross-members they had on hand on a given day.
Old Dec 20, 2013 | 08:33 AM
DIYMechanic
...or of whether the frame is from an F-250 or F-350....
Old Dec 20, 2013 | 12:51 PM
ReBilld's Avatar
ReBilld
This first pic is a '96 F250 ECSB 4x4 460 gas truck.....
This one is a '92 F350 CCLB 4x4 460 gas truck. I already removed the 460 motor mounts from this one cause it the one I'm doing the PSD swap on. You can see all four bolt hole for the PSD mount and both have the same two smaller holes as the PSD, no large hole for the oil filter.
This is a '97 F250 ECLB 4x4 PSD....
Old Dec 20, 2013 | 03:42 PM
dizzyfingers03's Avatar
dizzyfingers03
For what it's worth, I just looked at my F350 460 cross member. It's looks the same as a PSD. No big hole and 4 bolts / engine mount.
Old Dec 21, 2013 | 01:16 PM
Diesel_Brad
I am going to eat crow on this.
Just went out to my 96 460 truck. 2 medium sized holes like shown in pics.
My donor frame from my pulling truck was supposedly a 460 truck, but it has one large hole like a 5.8.
I am not even going to attempt to try and dig to get to the pulling truck
trap4x4
WTB - Parts & other
Oct 18, 2011 09:30 AM
clintp
Jan 11, 2007 11:25 AM
CrewCabCOE
Jan 10, 2005 04:35 PM
big block power
Dec 28, 2002 05:15 PM
