Modular V10 (6.8l)
Oxygen sensor replace
Old Dec 16, 2013 | 10:57 AM
VCB's Avatar
VCB
My '03 triton is showing code PO171, and the diagnostic reads no voltage from 02 sensor 1, bank 1. I don't know exactly where this sensor is located (I haven't looked yet). I think I would like to swap sensors between bank 1 and bank 2, then run diagnostic again. Is that a reasonable plan?
Old Dec 17, 2013 | 03:36 AM
Bently_Coop's Avatar
Bently_Coop
The o2 sensors are just after the factory manifolds on the y pipe.
Have you thought about using a meter to check voltage from the harness or to test the sensors resistance?
Either way if you do swap and the sensor is fouled your plan should work.
Old Dec 17, 2013 | 05:47 AM
sammie0126's Avatar
sammie0126
Not sure exactly what V10 you have but on my 00 V10 excursion they are on the back side of the pipes, this is the drivers side which is fairly easy to reach
Passenger side is a reach, you can see it in this photo only because my pipes are cut off during the header/exhaust project I was doing. You need octopus long arms and an O2 socket, or offset socket.
grey2112
Aug 12, 2015 12:05 PM
VCB
Modular V8 (4.6L, 5.4L)
Mar 29, 2014 07:34 PM
chrism
Modular V10 (6.8l)
Mar 20, 2008 10:49 PM
Hartwa
1997 - 2003 F150
Jul 28, 2006 02:48 PM
SZAlbNM
Jul 13, 2006 11:18 AM
