Steering Box?
Old Dec 18, 2013 | 02:48 PM
White Max's Avatar
White Max
Originally Posted by mrrish79
Has anyone put a Steering Stabilizer Kit on their truck before? I heard its suggested for older trucks with high mileage and trucks with tires bigger than stock.
I run one from Skyjacker to reduce tramlining with the wider than stock tires (33x12.50's). It can mask other steering issues, so I recommend sorting everything out before installing one.
Originally Posted by DBD7
my father in-law had a 96 F250 that had horrible steering wheel Lash. so bad that you would have to move the wheel 3 or 4 inches in either direction to keep it on the road. he told me to fix it there is an allen screw on the steering box that he tightened and it took up the play there.
I did not do this my self so I am not sure on the correctness of this and this only works if the play is in the steering box.
There is a lash adjustment on the steering box, however caution must be taken here. If you run the adjuster in too far, you'll have issues with return-to-center and "notchy" steering. There is a lash adjustment procedure that involves measuring steering effort, but most just go with the "1/8 of a turn at at time" approach.
Old Dec 19, 2013 | 08:24 AM
mrrish79's Avatar
mrrish79
I already have wider tires but only 10.50's and have decided the biggest tire I'm going with is a 31x10.50 my previous truck had a 6 inch suspension lift with 35's I've gotten the monster truck fever out of my system haha.
I agree and plan on finding the root cause before adding a steering stabilizer heck I should have put one on my last truck for sure it was all over the road.
where exactly on the steering box is the lash adjustment and good call on the 1/8" turn.
Old Dec 19, 2013 | 09:23 AM
White Max's Avatar
White Max
The lash adjustment is done via the set screw with the jam nut that's plainly visible from overhead. At the very least, verify that there is excessive lash in the steering box itself (and not elsewhere like the steering linkages) before messing with the adjustment. As I mentioned above, running the screw in too far can create a dangerous situation.
Old Dec 20, 2013 | 05:30 PM
mrrish79's Avatar
mrrish79
Well thanks again ill be looking at it tomorrow and hopefully it's as easy as a very small adjustment.
mike L
Sep 20, 2017 09:50 PM
bballcrf
Jun 11, 2014 12:17 AM
bigbeardbiii
1978 - 1996 Big Bronco
Mar 7, 2014 01:20 PM
mint350
Jun 23, 2010 10:48 PM
F250DUDE66
Dec 31, 2007 06:25 AM
