1978 - 1996 Big Bronco
new tires
Old Dec 15, 2013 | 07:26 PM
4X4 all the way's Avatar
4X4 all the way
new tires
I have a completely stock 1989 ford bronco xlt.I am looking at ATX Series atx slot rims from tire rack and they are recommending 33X12.5R15 tires.If you could tell me if those tires would workny advise or tips or anything would be great.Thanks
Old Dec 16, 2013 | 11:33 AM
Kemicalburns's Avatar
Kemicalburns
i believe those tires will fit with no lift, may have some rubbing on the radius arms perhaps.
what motor do you have? with stock gears you will take a mpg hit
Old Dec 16, 2013 | 02:01 PM
4X4 all the way
5.0L 302 automatic
Old Dec 17, 2013 | 12:26 PM
Kemicalburns
yea that combo will bring the Suck. dont use overdrive at all as it will lug the motor down to much and use even more fuel.
if its a good tire deal, and you have goals to eventually lift and regear then by all means go for it.
Old Dec 17, 2013 | 01:11 PM
4X4 all the way
What would u recommend because I would like to tun the biggest tire I can without anything breaking while I do body work
Old Dec 17, 2013 | 01:12 PM
4X4 all the way
*to run the biggest
Old Dec 17, 2013 | 01:55 PM
arctic y block's Avatar
arctic y block
I run that size tire on my 85 Bronk in the summer.
It's a 351W HO. They rub the arms just a little in
a hard over turn around. Just enough to knock the
mud off is all. And yes with the C6 with no overdrive
I get a little worse MPG unless I am rock crawling.
than it's the same.
Old Dec 18, 2013 | 10:07 AM
Kemicalburns
well i say get them if the price is right. just dont expect to use Overdrive much
Old Dec 18, 2013 | 02:38 PM
bra$$monkey's Avatar
bra$$monkey
It all depends on your differential gears. The lower the better (higher number).I had a 2005 jeep that couldn't go 70mph after
Adding larger tires.
I put 33s on another jeep (scrambler) that didn't drive any differently.
My guess is, because the 5.0 you have tall gears (numerically low) to give better fuel econ.
But cheap 33s are hard to pass up. I say do it & never look back
Old Dec 18, 2013 | 03:28 PM
arctic y block
With the 33's on "The Bronk" I can still cruise around 70 MPH.
But 80 is about all she has got and that down hill with a tail wind.
With the 31's she will snap to 80 quickly and run there all day.
Never have topped her out and prolly never will. Even the speed
run to the clinic with a kid having possible appendices problems
I only ran 85 with lots of peddle left. On theses roads
that are built for 50 MPH that's plenty fast enough.
It sure rolls easier with the hubs out at high speeds also.
BigRy
Sep 5, 2009 09:41 AM
liquid 1
1997 - 2003 F150
Mar 14, 2007 10:41 PM
2006HarleyF250
Dec 12, 2005 04:54 PM
gwwesch1983
Dec 9, 2003 05:08 PM
Guy
Feb 6, 2002 09:05 PM
