1978 - 1996 Big Bronco
Alternator charging issue
Old Dec 17, 2013 | 06:33 PM
bra$$monkey's Avatar
bra$$monkey
HI guys - 91 Bronc 5.0 auto trans auto hubs
I just had the engine replaced - I bought the beater with a rod knocking & had a local shade tree drop in a junk yard replacement.
Lucky for me the JY engine had been rebuilt - it runs strong.
BUT.....you get what you pay for.
The alternator does not charge at all. I found a broken thingy & I'm not sure what it is.
The wire harness plugs into the bottom of the alternator. About 6 inches down the line the harness splits into a Y & about 6 inches up the other side of the Y is a plug.
That plug believe it or not is still plugged into something broken & smashed. I can't see where it should go or what it should be attached to.
Any help will be appreciated. I can get pictures later.
Old Dec 17, 2013 | 07:33 PM
bra$$monkey
https://plus.google.com/u/0/photos?p...37863035187584
Old Dec 18, 2013 | 09:24 AM
bra$$monkey
Anyone know what this used to be?
Its on the harness coming from the alternator - I thought TPS for a while - but now I dont think so.
Gotta figure this out.
Old Dec 18, 2013 | 10:04 AM
Kemicalburns's Avatar
Kemicalburns
i believe that goes into the back of the alternator
what year 5.0 did you drop in and did you reuse your alt and such from the bad motor?
Old Dec 18, 2013 | 10:14 AM
bra$$monkey
Reused my old alt. Eng came from a 90 f150.
Kept my old throttle body too.
The back of the alt? So is this a voltage regulator?
Old Dec 19, 2013 | 08:16 AM
bra$$monkey
Fixed it. Voltage reg.
Walleye Hunter
Jun 1, 2016 06:17 AM
NW 150
May 7, 2015 08:25 PM
GaRedneck91
59
Jan 10, 2015 09:40 PM
86f250XLT-4x4
Apr 11, 2013 09:27 PM
mmmchickenboy
Jan 4, 2012 11:23 AM
