limited slip question
Old Dec 15, 2013 | 07:09 PM
trevorrules's Avatar
trevorrules
I have a 95' f250 4x4 I was wondering if the front end or front diff. is limited slip when its in 4 wheel drive...any ideas??????
Old Dec 15, 2013 | 07:18 PM
Evan_P's Avatar
Evan_P
Look at the door sticker. If it has a 3 digit axle code instead of two it has a front limited slip.
garthneddy's Avatar
garthneddy
It's most likely open diff. You can decode the door sticker to find out your gear ratio and differential type.
You can also look at the axle tag bolted to the covers (or axle beam since its TTB). If your axle ratio is 4.10 with an open diff you should see a 4 10 stamped on it. Limited slips have an "L" where the space would be.
Old Dec 15, 2013 | 08:46 PM
trevorrules
well damn ... I don't like that at all the limited slip
Old Dec 15, 2013 | 08:53 PM
garthneddy's Avatar
garthneddy
Why would you want an open differential instead of a limited slip?
Old Dec 16, 2013 | 08:39 AM
dixie460's Avatar
dixie460
Probably because when you're off road, limited slip is hardly an improvement over open... *almost* as crappy but has a better chance of the working if you try the parking brake trick.
Go for a locker!
Old Dec 16, 2013 | 08:42 AM
Conanski's Avatar
Conanski
As delivered Ford LS diffs are pretty poor for offroad traction but that's easily fixed with a shim kit and/or a clutch pack restack.
Old Dec 16, 2013 | 11:50 AM
Nothing Special's Avatar
Nothing Special
I've never had a limited slip in a front axle, but I had a locker in one for a little while, and I'll never do that again in a 4wd that I plan on using on snowy highways. When only one front tire loses traction (like as you start to change lanes and the left tires hit the snow between lanes) the front tire with traction (the right in my example) not only tries to torque-steer the truck to the left like when the same thing happens with a rear locker, but also the torque steer tries to turn the steering wheel to the left as the knuckle tries to pivot on the ball joints. The result was that the truck moved 10 feet to the left before I could catch it. Fortunately the lane was empty so I didn't hit anything. That happened in the first snow storm I drove in after putting in the locker. I got off at the next exit and unlocked the hubs, then took the locker out and went back to an open front diff the first chance I got.
A limited slip would tend to do the same thing, but not quate as badly (especially if it's a really weak limited slip). But I'll never have anything other than an open diff (or a selectable locker that's open when unlocked) in the front axle of a winter street-driven truck.
4mil
6.7L Power Stroke Diesel
18
Aug 21, 2023 11:48 AM
crazy96863
Sep 16, 2014 12:38 AM
Rulebreaker
Bronco II
Dec 5, 2004 11:30 PM
dassmoof
1978 - 1996 Big Bronco
Jan 30, 2003 04:51 PM
cw50must
Mar 23, 2002 03:08 PM
