6.0 probs??
Old Dec 15, 2013 | 11:46 AM
Carl Rochester Jr.'s Avatar
Carl Rochester Jr.
6.0 probs??
i have an 04 f250 with 6.0 has new hpop new icp new cps
still get code p2290 low oil pressure
now just driving it cut off with no restart sit over night and fires right up
ran for 20 minutes cut off n wouldnt restart... sit over night again n starts fine.. need help asap!!!!! thanks
Old Dec 15, 2013 | 12:44 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Do you have an OBDII monitor? Need to see ICP/IPR readings. Could be IPR. Is it an eary or late model '04 (ICP on valve cover) Have you tried cranking with ICP disconnected?
Old Dec 25, 2013 | 09:54 AM
Carl Rochester Jr.
icp 294
ipr 10%
ficmp 48.5
ficml 12
Old Dec 25, 2013 | 10:04 AM
Maxium4x4's Avatar
Maxium4x4
Try unplugging the ICP and let it default
Sent from my C811 4G using IB AutoGroup
Old Dec 25, 2013 | 11:23 AM
78fordman's Avatar
78fordman
Originally Posted by Carl Rochester Jr.
icp 294
ipr 10%
ficmp 48.5
ficml 12
Do you have crank sync? 294 is too low and so is 10% IPR. Teh ECM should be calling for a lot more IPR% like 77%.
Old Dec 25, 2013 | 12:04 PM
Fal-308-Win's Avatar
Fal-308-Win
Was the engine at operating temperature (190* ECT) when these numbers were taken ? If not I'm with Rusty on this one, IPR failed in the " open position ".
Emilio2496
Aug 23, 2015 01:13 PM
cope1972
May 17, 2014 11:32 AM
Kirkmossow
Aug 13, 2013 10:02 AM
tqii42
Jan 26, 2012 12:08 PM
mickpowell1967
Feb 6, 2011 10:26 AM
