Starting Issue
Old Dec 13, 2013 | 09:15 PM
67duster's Avatar
67duster
Starting Issue
Stock 73, 360 with auto transmission. starts and runs great when cold. once its warm it doesn't want to start. when you turn the key it fires for a split second and then nothing, just motor turning over. again hit the key and it fires for a split second and then nothing.
Thanks
Old Dec 13, 2013 | 11:16 PM
Dasher400's Avatar
Dasher400
Manual or electric choke?
Old Dec 14, 2013 | 12:05 AM
Westcoast Highboy's Avatar
Westcoast Highboy
Possibly fried points. When they are badly worn or pitted, the resistance goes up considerably when warm causing the circuit to fail.
I would be inclined to do a full tune up on the engine first if you have not already done so, (plugs, points and condenser, fuel filter etc.) so you have a solid base line and go from there.
Last edited by Westcoast Highboy; Dec 14, 2013 at 11:38 AM. Reason: Added more detail
Old Dec 14, 2013 | 07:53 AM
MeanGreen460's Avatar
MeanGreen460
could be a choke problem or points I'd check choke first
Boodrow379
Feb 18, 2014 08:28 AM
pit_of_pity
Oct 2, 2009 10:29 PM
gruntwannabe
Apr 11, 2006 06:03 PM
green52
Mar 22, 2005 09:26 PM
UglyF250
Jan 24, 2002 06:00 AM
