Heater core
Old Dec 13, 2013 | 08:11 PM
Gembone's Avatar
Gembone
Heater core
I recently fixed my heater panel controls and blower motor speed switch. Now I can smell the undeniable stink of antifreeze. I had planned to change it out, but wanted to make it through the winter.
In my internet searches I have run across some heater cores that boast Hi-output. Has anyone had any experience with these? Are they the same thing and just trying to cash in on calling it HO?
Old Dec 14, 2013 | 05:58 AM
jowilker's Avatar
jowilker
Greg, They are less than 30 bucks new, check your local parts house chain for your truck to see if both are available. I think one is slightly larger than the other. You may be able to fix it with a torch & a little solder. You should have it swapped out in under an hour.
If your truck leaks as much air as mine does adding a second would not make a heck of a lot of difference.
John
Old Dec 14, 2013 | 07:25 AM
51MHF5's Avatar
51MHF5
When I rebuilt my cooling/heating system my trusted supplier strongly recommended it. No regrets...especially for the couple extra dollars
Old Dec 14, 2013 | 10:32 AM
crazed87bronco's Avatar
crazed87bronco
I rebuilt mine before there was 2 listed at the parts store basically one just had a bigger core then the other for more heat I'd get that One price ain't much difference.
Old Dec 14, 2013 | 04:31 PM
Gembone's Avatar
Gembone
Thanks for the info guys. I just wanted to make sure there was a difference and not just a gimmick.
I will check around the local chains and see what is available.
Old Dec 16, 2013 | 02:17 PM
Freightrain's Avatar
Freightrain
I'd get the bigger one, if available. Lord knows mine only got HOT in the summer time LOL!!! Get on the highway in the winter and you could just feel the heat disappear.
Lucky they are VERY easy to replace. Way easier then any new vehicle for sure. Hand full of small screws and it comes right out under the dash.
Old Dec 16, 2013 | 04:09 PM
jowilker's Avatar
jowilker
FYI, I think there is a little difference in the size, and not sure the larger one will fit. Check it out.
John
Old Dec 16, 2013 | 06:20 PM
JEFFFAFA's Avatar
JEFFFAFA
You might check on the dimensions Greg. Maybe just core thickness so the bigger one will fit. Ford only lists one for heater and one for the factory A/C box.
Old Dec 27, 2013 | 09:52 AM
Gembone's Avatar
Gembone
Well, I have checked all the local places and no one even lists an HO version. I will go with the standard locally since it has a lifetime warranty. Thanks for all the info guys.
Old Dec 27, 2013 | 10:11 AM
MavSprint's Avatar
MavSprint
Rockauto.com lists the different size cores with dimensions and pictures. I'm waiting to pull the core out of my '81 to see what size it is and if the larger core will fit before ordering a new one.
Old Dec 27, 2013 | 10:19 AM
Gembone's Avatar
Gembone
I know that I can order the larger one. For me I would rather deal with local for warranty reasons. Especially if it is ever to fail and need replacement.
Also the local part is only $20 with a lifetime warranty. The ones online seem to have at best a 2 year.
Old Dec 27, 2013 | 11:12 AM
JEFFFAFA's Avatar
JEFFFAFA
Greg. Carefull of that cheap one. A few girlfriends ago had an aftermarket cheap heater core she had bought before meeting me for her 1991 F150. It also had a lifetime warranty. I installed it kicking and bucking. That thing was SO cheesey it was unreal. I knew it wouldn't last a year. The hose tubes were not brazed in. They were o-ring sealed and held in with some real thin barely crimped over collars. And I was right. Good thing that heater core is super easy to change!
Old Dec 27, 2013 | 12:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Hi output heater first listed in 1973.
D3TZ-18476-C (replaced C5TZ-18476-B & C7TZ-18476-A) .. Heater Core / Obsolete
Applications: 1965/66 F100/250 with fresh air heater / 1967/72 F100/750 except 1968/72 F100/350 with factory installed integral A/C
1973/79 F100/350 & 1978/79 Bronco except with factory installed integral A/C, hi output heater, Hi/Lo comfort vent system.
Old Dec 27, 2013 | 02:05 PM
Gembone's Avatar
Gembone
cool, thanks for the info and experience.
Now to try and find one.
Old Dec 27, 2013 | 02:49 PM
JEFFFAFA's Avatar
JEFFFAFA
Greg. Interesting findings with the Ford number. Running on Bill's lead I see his D3TZ H.D. Dent number is the same as a Bump's standard heater core. He mentioned That Dent number replaced C5TZ18472B and C7TZ18476A.
C5TZ18476B......factory heater... 65/66 F100/F250
C7TZ18476A......factory heater (non-A/C) ..67/72 F100/750
I am just explaining it differently than him. So the Dent's standard heater core must have been smaller than a Bump's.
