c6 to e4od swap help
Old Dec 13, 2013 | 06:23 PM
flaboy1979's Avatar
flaboy1979
I'm looking to swap my worn out c6 in my 1989 f250 for a e40d I picked up for next to nothing it came out of a 89 also I know my drive shaft will have to be replaces and I need to round up some wireing and other electronics from th junk yard any one know what all I will have to get thanks
Old Dec 13, 2013 | 06:48 PM
Chevy_Eater's Avatar
Chevy_Eater
I wonder what you'd do for the VSS? Does the '89 have an electric speedometer? If so you might have one already. Otherwise I'd think you'd need a rear end with the VSS in it. Of course you'll need the TPS and the ECM + wiring. I'm pretty sure '89 had the OD rocker switch on the dash so you might get away from having to change your column for the OD switch/light.
From what I've read here it's way easier to get an aftermarket controller rather than try to wire it up factory, but it's supposed to be very price too.
Then there's the obvious hardware, flexplate/flywheel, maybe the cross member, torque converter (although it might be a good idea to install a new TQ while you have the tranny out.)
Old Dec 14, 2013 | 02:07 PM
Red454sedgwick's Avatar
Red454sedgwick
In 89 it was an option so if you find a similar truck it's basically a bolt in job.
As for the wiring you will need the throttle position sensor and the little adaptor in the injection pump. I got my after market controller from The US Shift Transmission Control System. They programed the controller, built made wiring harnesses for 700 bucks. if was fairly simple to install. The program to change the **** tables is kind of hard to figure out at first. I run mine off the abs sensor in the rear end
The stock tc aren't the best they are the cause of many of the stock e4od problems. I got mine from racer-x.com. I have the 600 horse converter and like, but for a stock idi you don't need that one
https://www.ford-trucks.com/forums/1...cks-build.html
this is the tread on my truck
Old Dec 14, 2013 | 08:30 PM
flaboy1979's Avatar
flaboy1979
That's what I thought I'm just going to put it on creigslist and make a few dollars
dads red truck
Oct 9, 2012 11:08 AM
rolape2
Sep 23, 2012 10:32 PM
Brant Bowrifle
May 17, 2012 05:46 PM
MUSKRATT2
19
Jan 25, 2012 05:44 PM
cannonfodder
15
Jan 10, 2009 06:24 PM
