Removing the Air Pump.
Old Dec 13, 2013 | 02:06 PM
boonslick's Avatar
boonslick
Hello and good afternoon.
I want to remove the Air Pump and all of the associated plumbing except what is absolutely necessary.
I have another thread in my group and one reply stated that my fuel mileage will decrease.
I am currently installing a new exhaust system starting with pacesetter shorty headers into a y-pipe through a Hi-Flow Catalytic Converter (no air tubing) with an Inco 12" Glass Pack finally terminating at the rear bumper with a Stainless Steel tip. From collector to tailpiece will be 2.5".
What is your view on this decrease of mpg?
Thank you.
Boon
Old Dec 14, 2013 | 12:44 AM
xlt4wd90's Avatar
xlt4wd90
Most modern engines using HEGO sensor may be very critical of exhaust contents, and they may use the AIR system as part of that control. So removing it can upset engine control.
The AIR system also helps the catalytic converter do its job, so removing it will also make emissions worse.
Old Dec 14, 2013 | 03:46 AM
ashleyroachclip's Avatar
ashleyroachclip
Probably don't need to worry about it.
And there is a factory plug for the back of the head, if you are wanting to get rid of the pipe that crosses between the heads on the back.
There are a ton of rigs that don't have air pumps to the cat . And they work just fine.
The big deal is if your state , or the jurisdiction you live , has a smog inspection that this vehicle is not exempt from .
Old Dec 15, 2013 | 03:56 PM
baddad457's Avatar
baddad457
X 2 on this. My 96 E150's 351 has no Thermactor system, never did. I removed the system from a 95 F150's 351W too, the mileage didn't seem to suffer
Old Dec 15, 2013 | 04:17 PM
boonslick's Avatar
boonslick
Catalytic Converter
There have been advances in the modern Catalytic Converter. Now they have Hi-Flow without air tube that remove pollutants much better than the older Cats.
I see a problem in that their is so much that is not needed on an engine. It is just if you have this then this is also required including vacuum hoses.
Geez, you can hardly get your hand in some places.
I have been provided with a wealth of knowledge from this forum and after "putting it all together" will install a Hi-Flow Cat without air tube.
I bought a 1974 new 3/4 Ton truck and I use to sit on the wheel well INSIDE the engine compartment.
Take care
Boon
P.S. There are a lot of "schools for thought" so it is up to the owner as to what mods he or she wants to do.
Old Jan 3, 2014 | 12:47 PM
boonslick's Avatar
boonslick
Removing Air Pump
What is a HEGO system and do you think that my 87 5.0L has it?
I am purchasing a Hi-Flow Cat without air tube. The current Cats remove hydrocarbons very well and further more are better than stock. This is my personal view of course.
All of the plumbing is unnecessary in these engines in my view so I will just eliminate it.
If it does not improve the performance and efficiency then I will just reinstall it.
Take care
Boon
Old Jan 3, 2014 | 04:01 PM
Cobra-Kai's Avatar
Cobra-Kai
Fuel Injection Technical Library » Oxygen Sensor (HEGO)
If you have an EFI and not a Carburator, then you hava a HEGO.
keiser blade
Aug 27, 2009 10:43 PM
fordfan2-4-84
Apr 22, 2009 08:52 AM
bensimmons_99
Mar 28, 2005 03:50 PM
gearshift101
27
Dec 7, 2004 08:18 PM
JRTART1963
1978 - 1996 Big Bronco
Jun 24, 2003 10:01 PM
