Fuel sending unit question
Old Dec 13, 2013 | 10:37 AM
CDN Sharky's Avatar
CDN Sharky
Hello again now I have a fuel question does anybody know where to find a fuel sending unit for my 1978 f150 sb rear tank that has a 3/8 inch output instead of 5/16. I was told since im going with 400 horse motor I need to get more fuel to the motor or ill run out when I floor it.
Old Dec 15, 2013 | 09:11 AM
CDN Sharky's Avatar
CDN Sharky
No Ideas...anybody?
Old Dec 15, 2013 | 11:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Who told you that bit iof information? I have never heard that before.
Have you called your local part stores and asked if they have different output hose size sending units?
MTS COMPANY, L.C. - Ford Pickup fuel tanks
1973-79 Ford Pickup Truck Fuel Tank
Old Dec 15, 2013 | 12:51 PM
fmc400's Avatar
fmc400
MSEE
The OEM sending unit is supposed to be 3/8 inch in the first place. Any sending unit you find with a 5/16-inch outlet is a reproduction error. Dorman sending units suffer from such an error. The sending unit I got from DC had the correct outlet size.
Old Dec 15, 2013 | 04:11 PM
CDN Sharky's Avatar
CDN Sharky
The guy at the parts store told me. Small town what can I say. The only sending unit he could get was 5/16 unless I get one for a mustang there 3/8 but nobody knows if it will work with the tank I have. May be I will have to talk to the local ford dealership and get one directly from them. I will also try and google dc and see if I can find one as well. Ok what does dc stand for. And also if it matters im using a 19 gallon rear tank its a 1978 f150 shortbox 2wd.
Old Dec 15, 2013 | 06:00 PM
CDN Sharky's Avatar
CDN Sharky
Cant find one anywhere on the net, sent some emails and gonna check with ford tomorrow.
Old Dec 15, 2013 | 06:11 PM
fmc400's Avatar
fmc400
MSEE
These aren't hard to find at all. Assuming you have the standard 19-gallon tank, this is the sending unit you need:
Fuel Tank Sending Unit w/ Aft Steel | Dennis Carpenter Ford Restoration Parts
I also recommend upgrading the float:
Fuel Tank Sending Unit Float | Dennis Carpenter Ford Restoration Parts
As I said before, the OEM sending unit is supposed to be 3/8". Forget all this nonsense about some "specialty" size that you were supposedly told about. You can surely find a sending unit cheaper through Rock Auto or just about any parts store, but as I mentioned, you run the risk of it being 5/16" (which, again, is wrong).
Old Dec 16, 2013 | 07:33 PM
CDN Sharky's Avatar
CDN Sharky
Thanks fmc400 I took the one I bought from local parts store back and ordered one with float from DC.
Old Dec 19, 2013 | 07:13 PM
JohnBOV43159's Avatar
JohnBOV43159
I bought the Spectra sender (on the right) along with a new 19 gallon tank and realized the hose outlet on the sending unit was the wrong size when I got it home.
I ordered the correct sender with a 3/8 outlet from Jeff's Bronco Graveyard (on the left) and it is better quality all the way around.
[/IMG]
Kamstutz
6.7L Power Stroke Diesel
May 18, 2015 03:48 PM
alchemist1
16
Jul 20, 2012 01:03 PM
BobbyFord
Aug 15, 2005 05:00 PM
higgy baby
Bronco II
Feb 24, 2005 09:19 PM
