FYI- locking hub interchange info
Old Dec 13, 2013 | 08:48 AM
10fords's Avatar
10fords
Thought I would share this real world info on locking hubs! I took the hubs off my 1986 f350 and put them on my 2000 f350 and they bolt up and work fine. I did not need any nut kit or whatever it is they say you need to adapt manual locking hubs from autolocks. However the 2000 f350 hubs do not bolt up tp the 1986. They slide in, but not far enough to put the retaining ring in. I did this because the hubs on my 2000 wouldn't disengage even after disassembling and cleaning/lubing them, and nobody has the milemarker manual hubs in stock right now. So it seems that any f250 with the dana 50 or f350 from at least 1986 on up should work. Hope this helps someone!- Scott
Old Dec 13, 2013 | 09:53 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Interesting
And your 4x4 works when engaged?
Old Dec 13, 2013 | 07:49 PM
10fords's Avatar
10fords
Originally Posted by Tylus
Interesting
Yep! I just did a small hillclimb on my property and the 4wd worked fine. I think I will have to plug the vacuum line for the hubs, but I haven't done it yet. I have had great luck with the older ford factory hubs and they are plentiful. In years of use and abuse with big tires, heavy loads, and beer behavior I have yet to have one fail. I might try to find a set and use them instead of buying new milemarkers.
Old Dec 13, 2013 | 08:14 PM
hav24wheel's Avatar
hav24wheel
78-04 F350 hubs will work.
99-04 F250 hubs will work.
Warn Industries - 4WD Standard Manual Hubs
There are some other years F250 hubs that will work also....
Fastback460
Nov 29, 2014 05:13 AM
stevestroke01
Oct 21, 2011 09:27 AM
wolfbike1500
Oct 26, 2004 08:12 PM
jmbatlanta
May 29, 2003 09:55 PM
