My '96 Ford F250 4x4 came with a set of Warn hubs. I assumed that I had to lock the hubs each time that I want to use 4h or 4l ranges and have done so with success.
I was looking thru the owners manual and found some handwritten notes about how to engage/disengage the hubs from inside the cab.
Does thise mean that these Warn hubs are autolocking and if so, what is the purpose of having the manual selectors on the hubs turned off?
The note said that if I change back to 2h and backup for about 12 feet, that the hubs would disengage - is this correct? and it went on to say that they would engage when in 4h or 4l - is this correct?
The Warn hubs currently on your truck are not the OEM hubs, they're an upgrade. Someone put them on the truck after the OEM hubs failed, or they got tired of OEM hubs working poorly. This is very common when dealing with the auto hubs on pre '99 trucks.
The notes written in the manual were the procedure for getting the OEM auto hubs to disengage.
I would continue to operate the 4X4 system as you have been.
Ok. I didn't know that. But a 96 does not, correct? That's before the "SuperDuty" came out. A 96 will either have the 3 or 5 screw auto hubs or manual hubs, correct?
Originally posted by NoMo The instructions posted sound like the ones for the mechanical locking auto hubs. They use centrifugal force to engage & dis-engage.
So does this mean that if I turn the hub dial to unlock after using 4h with the hubs locked, that the hubs are still locked until I roll backwards as directed on the instructions? OR can I take the lock/unlock indicator as being all I have to do to actually lock or unlock my hubs. Does WARN make a set of 'mechanical locking auto hubs' that fit the '96 F250?
NoMo is referring to the fact that the auto hubs lock "mechanically" ie by centrifugal force, rather than by vacuum pressure, as is the case for the hubs on the '99 and up SDs.
Without seeing your hubs, it's my guess that these directions DO NOT apply to your hubs.
(NoMo, correct me if I'm wrong here.)
With a typical WARN hub, the locking/unlocking action is done by rotating the **** on the hub. No further motion or actions are required. They can get sticky, and require a little forward or reverse motion to unlock, but that is NOT how they are designed.
Simply turn the hub to lock to lock, unlock to unlock, nothing else is required.
The procedure written in your manual is the procedure recommended by Ford for their "mechanical" auto locking hubs. These hubs were standard, and did NOT have a manual override or any way of manually locking the hubs.
I think you got confused by the exchange between jablestri and NoMo. The type of hubs NoMo is referring to are NOT common. It is far more likely that you have simple Warn manual lock hubs on your truck, put there by a practical, no non-sense guy. The standard auto locking hubs were very prone to failure and swapping them to Warn manual hubs was a pretty common practice.
Ok, clockwise is engaged, counterclockwise is dis-engaged. All you have to do is turn the dial, engage the t-case when needed, and your ready to rock and roll. When done, simply unlock the hubs and drive on. No need in going backwards.
