1978 - 1996 Big Bronco
Bronco exhaust system
Old Dec 13, 2013 | 01:20 AM
Edds's Avatar
Edds
Hey guys im new to this site and it seems like a site to get all my answers. I was wondering which exhaust system would be loud and aggressive for my 1996 Ford Bronco EB 5.8L? I was thinking of either going true duals straight piped or true duals with Flowmaster Super 10. What do you guys think?
Old Dec 13, 2013 | 06:46 AM
bra$$monkey's Avatar
bra$$monkey
I have flow masters on my 56 f 100 & straight pipe single on my 91 bronc with the 5.0 - which would sound the same as your 5.8
The straight pipe is loud & not too crackly but there is hardly any sound at idle.
My flow masters though tune the sound so when I'm at a red light (if the hot rod truck wasn't clue enough) people know I have serious performance under the hood. The sound at idle is amazing but under load it's not that different from my bronc.
So I ask you, will you be showing off the truck to friends in the parking lot or out on (or off) the road?
Old Dec 13, 2013 | 09:29 AM
Kemicalburns's Avatar
Kemicalburns
well frankly you have some challenges involved. 1 the transfercase is in the way of running True Duals, way to many bends would have to be made thus defeating the purpose of going this route. not to mention the expense. Your bronco has 2 cats and frankly needs them. I would recommend having a customer Y pipe built or a bassani y pipe installed, run dual hi flow cats, 3" exhaust and then run a single In/Dual out muffler of your choice if you want that duals look. Or just run have the exhaust dump right after the muffler.
the flowmaster mufflers in my experience Drone a lot in the cab during normal hwy driving, this can get old when your wanting to listen to the stereo or talk to your passengers.
you will want headers, Jba, BBK, Edelbrock all make good quality hardware.
a single well built exhaust will out perform duals on our rigs. if you are dead set on duals both pipes will end up running down the passenger side of the truck till you pass the Tcase. make sure an X pipe is added to the system to equalize the exhaust pulse otherwise it will sound like sheet.
good luck
Old Dec 13, 2013 | 09:56 AM
bra$$monkey
X2 on the cats. No shop in the US will touch an exhaust on a 96 w/o adding cats.
I honestly think you will be much happier with the flowmasters
Old Dec 13, 2013 | 10:14 AM
Edds's Avatar
Edds
I will be showing it off on the road.
Old Dec 13, 2013 | 10:18 AM
Edds's Avatar
Edds
good luck
Okay i think ill just stick to a single out. And I don't want to switch my cats because I live in Cali and I heard that switching cats is a high risk to pass smog. So I was thinking of buying shorty headers and leave my stock cats and then put in a brand new cat back exhaust system with 4' pipe or 2.5' to have some crackly noise (if it makes any)
Old Dec 13, 2013 | 10:49 AM
Kemicalburns
4" would be to large. 3" is large enough, thats how my exhaust is setup. I am running a hooker aerochamber muffler. its got great sound when i am on the throttle and simmers down nicely when i back off the throttle. This might work well in cali given the cops have an ear for loud exhaust. you back off the throttle and they would loose ya quick.
bassani makes a good exhaust system as well
Old Dec 13, 2013 | 11:31 AM
bra$$monkey
You don't need headers to run flowmasters. If your goal is aggressive sound just go from the cat back.
The size of your pipe is mostly for appearance as the computer will control the hp even if you open it up.
By the way. Wide open exhaust is good for top end high rim running. You want some back pressure if you are looking for off the line acceleration. 2.5in pipe is just fine
Old Dec 17, 2013 | 07:06 PM
Edds's Avatar
Edds
Okay cool. Would shorty headers make a bit difference or a little bit more?
Old Dec 18, 2013 | 10:06 AM
Kemicalburns
being that you have a 96, i am unsure if you could find headers that are legal although ones from a 95 bronco would work just fine i suspect.
I run shorties, some run long tube headers although fitment issues tend to come up with those and in cali you probably couldnt swing that.
Old Dec 18, 2013 | 10:09 AM
Edds's Avatar
Edds
Okay cool then. Ill see if I can find some legal shorties. Thanks
Old Dec 18, 2013 | 10:12 AM
bra$$monkey
Shortys will help quite a lot if you re tune your computer.
If you leave the stock tune the computer will hold it back no matter what cool mods you do.
Old Dec 18, 2013 | 11:17 AM
Edds's Avatar
Edds
Okay ill ask my mechanic if he does tune ups, he even recommended me to a guy that does custom exhaust systems. Ill ask the guy if he can tune it up.
Old Dec 18, 2013 | 12:33 PM
Kemicalburns
brass is talking about putting a customer Tune on the computer.
brass being that his system is Mass-Air OBD-II it will actually do well with a free flowing exhaust with out a custom tune. now if he had a new aftermarket cam and a set of heads i could see dropping the coin for a computer tune.
Old Dec 18, 2013 | 01:00 PM
bra$$monkey
Good to know. Still, traditional power adds are not as effective as you would expect.
Ford wants it's engine to outlast the warranty period and get decent gas mileage. So the tune is mild. It doesn't let the engine go all out. While exhaust & intake mods may make a small difference it will be less of a difference than you would find on a carburated engine because the tune is trying to keep everything low key.
If you are looking for power you are better served by spending your cash on a new chip, or a retune.
If you are going for sound go with exhaust.
If you want both get out the credit cards & do both.
*point to remember* tune the computer after you do your other upgrades as each upgrade will allow you to tune more power.
