It's late, the wind is blowing hard, it's cold as hell, and snowing.
The questions are how to verify if you have...
1: 2 or 4 wheel ABS?
2: 3" or 3-1/2" wide rear shoes?
....without climbing under the truck or pulling a rear wheel?
To order the rotor and wheel cylinders these are what they ask for.
VIN is 1FTJE34G1THBXXXXX
Engine = 460
Trans E = E4OD
Axle C2 = Dana 6250 Limited Slip 4.10
Brakes C
Int Trim BJ
Springs B4RS
GVWR Front 4050 lbs
GVWR Rear 6084 lbs
GVWR Total 10134
