351w engine build suggestions
Old Dec 11, 2013 | 08:35 PM
BuiltFordTough302's Avatar
BuiltFordTough302
Hello, I'm in the planning stages of my first engine build. I am swapping a 351w into a 1978 F150 4x4 short bed on 35's with 4:10 gears. I'd like something with good low end and mid range power. I could use some help putting together a parts list that will keep me in a safe range as far as compression ratio for pump gas. Any suggestions for aftermarket heads, pistons and cam selection would be much appreciated. As far as intakes, I'm leaning towards the Weiand Stealth topped with a 650 cfm carb.
Old Dec 11, 2013 | 10:40 PM
Conanski's Avatar
Conanski
GT40 heads at a minimum and select pistons based on the combustion chamber size to end up with no more than 9.5:1 static CR. What year is the 351 you're building? A roller cam is the way to go these days but it's expensive to put one in an older block, if you could start with a '94+ core it's a lot cheaper to do.
Old Dec 19, 2013 | 02:43 PM
1990f150kid's Avatar
1990f150kid
GT40 heads, headers, preferably long tube with a high flow exhaust, 2.5in into a 3in all the way back, a good low end cam which will give you massive low and mid range and a good distributor. Heck maybe even 1.7 roller rockers. should be well above the 300hpmark and well near 400lb-ft and with that set up probably the best gas milage nd have a perfectly reliable and powerful motor. for mine ive got the headers, rockers and cam ready to go, just waiting on my gt40 headers to be ported and polished.
majic
19
Feb 3, 2020 05:31 PM
Atlfan65
Jun 28, 2017 02:19 PM
dying breed racing
21
Oct 13, 2014 01:11 AM
jejdavis
Apr 18, 2011 03:15 PM
02FX4Dude
26
Dec 30, 2004 06:46 AM
