Crew Cab Interior Light Mod
Old Dec 12, 2013 | 01:16 PM
TRENT310's Avatar
TRENT310
Originally Posted by SavageNFS
When did Trent add the MM? I missed this...
Right shortly before this happened...
Old Dec 12, 2013 | 01:18 PM
TRENT310's Avatar
TRENT310
Originally Posted by Tim Young
Sounds good guys, Trent what brand and bulb numbers did you use? I will have to order a set as no one around here carries them.
Thanks Tim
Those are 42mm Festoon lights I used, all 3 are the same in there. They come in a variety of lighting colours and LED elements ... in this case you just need directional lighting as there is no point lighting up the inside of the headliner.
Old Dec 12, 2013 | 02:09 PM
SavageNFS's Avatar
SavageNFS
I guess I just thought there would be more said about it. When did this occur? I'm happy for you and hope you enjoy it
Old Dec 12, 2013 | 02:29 PM
ScottyDog's Avatar
ScottyDog
Savage - Looks like Trent's been holding out on the FYI for us for sure...
That's exciting Trent, gotta put a smile on your face!
Hopefully, I'm not too far behind you (literally)
Old Dec 12, 2013 | 02:52 PM
SavageNFS's Avatar
SavageNFS
It was over the summer...I just forgot. Getting old sucks
My apologies, Trent
Old Dec 12, 2013 | 09:37 PM
LaxPlaya21's Avatar
LaxPlaya21
Hey Trent, great mod! Are you an electrical engineer? I guess my only concern would be heat build up if left on for a long time. Any other possible drawbacks?
Old Dec 12, 2013 | 09:55 PM
TRENT310's Avatar
TRENT310
I work on electronics, instrumentation/automation, and telecommunications stuff all day haha.
The LED lights don't run hot. They have a heatsink but they merely ever get warm to the touch, not hot like the original incandescent lights.
The original lights could also be left on for a long time as well if the key was in the ignition. There is a battery saver relay that opens up and takes all the interior and exterior lights out if you leave them on, which is a nice feature (except when you're trying to use the vehicle lights as work lights and they keep shutting off on you!) - basically with this mod I'm not adding any more power (and therefore heat) dissipation to the light fixture than it had originally, just changing the "logic" to turn on lights when I want them to. Previously I would open the door and reach up and flip the switches if I needed more light, then I figured this could be modified to do that for me automatically! Necessity is the mother of invention isn't it?
Old Dec 12, 2013 | 11:21 PM
TRENT310's Avatar
TRENT310
I'm allowed to derail my own threads right?
I'm sometimes cryptic with my posts in the 1-page or WIH thread.
I did the delete pipe on Canada Day, July 1 this year. Celebratory coal rolling?
Started off like this
Pulled EGR tube
Once again, thanks to Darren for making the Mini Maxx possible.
Old Dec 13, 2013 | 08:10 AM
SavageNFS's Avatar
SavageNFS
yeah, I remember the flashlight pic now, vividly. I went out in the garage and did the same thing to mine with the exact same results
Old Dec 13, 2013 | 08:31 AM
Jigger2020's Avatar
Jigger2020
Now that we're way off topic why did you plug the EGR pipe...
Old Dec 13, 2013 | 08:32 AM
SavageNFS's Avatar
SavageNFS
That's kind of his (our) point. We didn't clog it...it was clogged when we removed it.
ScottyDog's Avatar
ScottyDog
Dang you are gettin' old Savage you remember the flashlight test, but not the empty 1/2 rack box of BlueRibbon on the floor...
Old Dec 13, 2013 | 08:43 AM
  #28
Jigger2020's Avatar
Jigger2020
10 - 4
Old Dec 13, 2013 | 08:45 AM
  #29
SavageNFS's Avatar
SavageNFS
I highly doubt that's Trents...
Now if that was my shop . Well, ya
Old Dec 13, 2013 | 08:47 AM
  #30
caverjoe's Avatar
caverjoe
should the piece of dodge be allowed to park inside?
