Sponsored by: Auxito
PS Fluid
Old Dec 11, 2013 | 09:04 AM
Amnfoxtrot's Avatar
Amnfoxtrot
6th Gear
PS Fluid
hey guys, i got a 2002 Ford F150 with the 4.2L.. in the book it says the PS should be mercronV..only problem is, i have mercron LV and mercron XP and dextron.. the only issue is that in order to get mercron 5. we have to fill out alot of paperwork and await a week to get it all approved.... so my question, will dextron, mercronLV pr mercron SP work????
thanks
Old Dec 12, 2013 | 08:27 AM
Bluegrass 7's Avatar
Bluegrass 7
LV should work ok in that application.
What's this about filling out paper work and getting approval for transmission fluid if you don't mind?
Good luck.
Old Dec 13, 2013 | 06:55 PM
steve(ill)'s Avatar
steve(ill)
steering fluid type is generaly not that important, so they use the same fluid that the transmission is filled with. What are you using for trans fluid in the 2002 ?
Old Dec 13, 2013 | 08:35 PM
cb_13's Avatar
cb_13
If you have the typical dexronIII/mercon I would use that because it tends to be the cheapest. If not any transmission fluid should work just fine. The steering system just needs a basic hydraulic oil, all transmission fluids are a hydraulic oil just with different additive packs.
Shadowrider123
Sep 12, 2019 01:35 PM
mark4000
1983 - 2012 Ranger & B-Series
Jul 29, 2011 07:09 PM
5.8F250
May 11, 2011 05:30 PM
axel 56
Apr 30, 2011 08:11 PM
kel1306
Oct 26, 2007 03:52 PM
