C6 Thrust Washer Kits??
Old Dec 9, 2013 | 11:12 PM
Aaron-71's Avatar
Aaron-71
Would a thrust washer kit be useful for a C6 Do-it-yourself rebuild?
I've seen a few of these kits on eBay and am wondering if anyone has had any luck with them.
Not sure if it'll be useful to me because I'm ordering a master rebuild kit with soft and hard parts.
Can anyone decode this tag on my C6?
The tag reads:
PGD.............BE5..............B20
D9TP.............LA................058076
NumberDummy?
Old Dec 10, 2013 | 09:05 AM
grinnergetter's Avatar
grinnergetter
I would think they would only be needed if your originals are damaged or really worn out. However you are "already in there".
I just used a basic rebuild kit from Summit.....so far, so good.
Old Dec 10, 2013 | 10:22 AM
Aaron-71's Avatar
Aaron-71
Did it come with thrust washers?
Every kit I see online doesn't list thrust washers as a part that the kit comes with.
Old Dec 10, 2013 | 10:39 AM
lbcarguy's Avatar
lbcarguy
Selective thrust washer
Good morning,
The front pump thrust washer is selective, meaning you can buy varying thickness versions to ensure the input shaft endplay is correct. You should measure endplay before you take the trans apart with a dial indicator. I do not have my manual at work with me so do not have the end play specs with me.
Generally, the thrust washers do not wear out unless there is a metal/hard part failure in the trans, like a planet gear that fails and sends metal through the trans. I have never replaced a set in any C4 or C6 I have rebuilt.
If you did not measure end play when you took it apart, measure it when you reassemble and if it is OK, you are set. If it is out of spec, get the correct size front pump washer. Most trans rebuilders can help you get the right one. The replacement may be plastic. I have used both types, no problem.
Mike
Old Dec 10, 2013 | 01:41 PM
Aaron-71's Avatar
Aaron-71
Originally Posted by lbcarguy
Good morning,
Mike
Great info!
I'll have to do some reading up on how to measure endplay of the output shaft to see what I have and if it's in spec or not.
I'm not sure what use a dial indicator would be for measuring endplay, but I guess that will come up when I read up on it.
Reps for the great info. Learned something new!
Old Dec 10, 2013 | 04:40 PM
lbcarguy's Avatar
lbcarguy
More selective thrust washer info
Hi,
Here is a photo of endplay checking (not a C6 but the setup is the same).
My 78 Ford shop manual shows endplay can range from 0.008 - 0.042in. Ford offered three selective thrust washer sizes: 0.056-0.60, 0.073-0.077 and 0.088-0.092.
Measure the endplay. If it is out of spec, measure the thickness of the current selective thrust washer (the big one on the front pump). Then select a size that will bring it back into spec. If you are not sure how to do all that, or do not have the tools, at a minimum, rent/borrow a dial indicator, then take that measurement and your selective thrust washer to a good trans shop and have them measure yours, then get you the correct replacement.
Happy Rebuilding.
B-2
Dec 10, 2012 06:54 PM
401477534
Apr 18, 2011 10:52 PM
rusty70f100
Feb 26, 2004 01:49 PM
Ford79
Aug 20, 2002 06:56 AM
keys
Dec 23, 2001 02:05 AM
