Engine swapping a 65 f100
Old Dec 9, 2013 | 03:38 PM
Gearhead559's Avatar
Gearhead559
sp the 352 is done for. hole in a piston and valves sunk thru theseats etc.
its done
have a complete efi 302 harness and ecu im going to swap in.
going to use a c6 to make it easier instead of a aod
i need to know whats up with the frame stands. i know the FE is different from the 302/351w. but is there a away to adapt to the fe frame stands, or do i just need to find some 302/351 frame stands?
many thanks ahead of time.
alos need to know what i need for a disc brake swap up front as well. would love to have power assit
thinking of even doing a ps swap while im at it
and if there is a place that sells the salvage parts i need please give me a link or info!lol
Old Dec 9, 2013 | 04:04 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Info on the 302 swap - tons of info but this is an example. Search a bit and you'll find lots of reading.
https://www.ford-trucks.com/forums/1...o-66-f100.html
Info in here on the disc brake swap. Again, search for a bit and you should be able to find all the info you should need.
https://www.ford-trucks.com/forums/1...1966-f100.html
Both ideas have been done - and discussed in numerous threads.
Old Dec 9, 2013 | 04:06 PM
Gearhead559
oh im sure, im always a lurker on the site here for the great info but my search skill must be broken cause all the threads i found lead me to dead ends!..lol
that and im mainly looking for a source for the parts needed in this aswell
Old Dec 9, 2013 | 04:28 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Most seem to source their parts from a 73-79 donor truck with disc brakes.
https://www.ford-trucks.com/forums/1...e-options.html
My search seems to work too well. Too much info and not enough time to read it all.
daltonjamesadams
Feb 8, 2019 10:06 AM
kre8speed
Jan 17, 2009 11:31 PM
1BaldGuy
Jun 3, 2008 07:30 PM
r_reed
May 12, 2007 12:10 PM
gurns29
21
May 30, 2004 08:14 PM
