Re: Cold running T SAT
Old Dec 14, 2013 | 01:11 PM
  #31
Rusty Axlerod's Avatar
Rusty Axlerod
Originally Posted by npccpartsman
With high temps only in the very low 30's I could get 188 on the highway but at a stop light it would drop into the 170's. Talk about sucking fuel.....
I'm also doing a cold soak study on my sensors as they seem to be off but they match each other exactly on cold starts. After 16 hours they are 10* higher than ambient...
Just from watching my truck, I do believe engine temp has a impact on fuel consumption. It is drinking fuel very quickly on a cold start! When I had the intake off it was a gummy mess also, right down into the intake ports on the heads. I think cold temps may contribute to that also. My sensors are within a couple of degrees of each other but seem to always be 6-8 above ambient no matter if it sits a couple of days .
John;
Did you put the cardboard behind the grill, up from the bottom? Did you use any attaching hardware or did it just stay in place?
Weather here today is a warm 58 with rain and the garage is full of other projects so climbing under the truck isn't an option. I have to work tomorrow so it looks like a goof-off day for me hmm, maybe a nice nap.
Old Dec 14, 2013 | 02:35 PM
  #32
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
It does because with the truck cold, it doesn't burn the fuel as well Because it's not getting as hot as it needs to.
I had this problem earlier this month when my truck would hang around 180 and never get hotter. My mileage suffered and the truck could het out of its own way, but as soon as I swapped in a new Motorcraft thermostat, I easily saw 190+ engine oil and coolant temps. My truck now runs noticeably better now that it gets up to the temp international and Ford meant for it.
Old Dec 14, 2013 | 06:12 PM
  #33
Snuggyworm's Avatar
Snuggyworm
Originally Posted by Toreador_Diesel
It does because with the truck cold, it doesn't burn the fuel as well Because it's not getting as hot as it needs to. I had this problem earlier this month when my truck would hang around 180 and never get hotter. My mileage suffered and the truck could het out of its own way, but as soon as I swapped in a new Motorcraft thermostat, I easily saw 190+ engine oil and coolant temps. My truck now runs noticeably better now that it gets up to the temp international and Ford meant for it.
I'm glad u resolved tat one. Lol. Lord knows if we got more stuff to do. Lol.
Sent from my iPhone using IB AutoGroup
Old Dec 14, 2013 | 06:41 PM
  #34
Yahiko's Avatar
Yahiko
Well with the warmer temps here (45º) I guess I need to remove
the blocker. I was seeing 200º EOT and 198º ECT. and
IAT2 or about 98º~103º.
Sean
Old Dec 14, 2013 | 08:34 PM
  #35
Per4mance's Avatar
Per4mance
I bit the bullet and replaced the stat.....waste of time....ordered a winter cover from FIA
Old Dec 14, 2013 | 10:08 PM
  #36
Misky6.0's Avatar
Misky6.0
Sean
Interesting, i drove 200 miles couple weeks ago with my fia cold front on (w/little vents open) ambient was 75-82. My ECT stayed 190-195 my EOT 205-210, i have external BPD oil cooler, and was using a/c and averaged over 22 mpg..
I was amazed the coolant remained normal. I was planning to stop and remove the FIA when temps got higher, but i never did.
Made me realize how effective the cooling system is on the 6l.
Sent from my Sprint PC36100 using IB AutoGroup
Old Dec 14, 2013 | 11:24 PM
  #37
Yahiko's Avatar
Yahiko
Well I am running with cardboard and it between the intercooler and the
radiator. It's a fairly full fit. So not that much air is getting around.
I picked up some plastic board that I will replace the paper cardboard with.
The next one will have some space for air to get around a bit more.
Sean
BTW : As soon as I was off the throttle the temps dropped fast.
Old Dec 15, 2013 | 01:12 PM
  #38
Ian123's Avatar
Ian123
So is the correct place in between the radiator and intercooler? I have mine behind the grille and it does absolutely nothing. Temps are still 182-184
Old Dec 15, 2013 | 03:37 PM
  #39
Yahiko's Avatar
Yahiko
The reason I placed mine there was to help keep to dry and
to see if I could keep air moving over the transmission, power
steering coolers, the condenser and intercooler.
Now that I have a large enough plastic board section I am going
to replace it with that and not have to worry about it getting wet.
Sean
Old Dec 15, 2013 | 08:26 PM
  #40
Rusty Axlerod
38* outside this morning. Truck made it to 184. Exact same drive, same temp leaving the driveway. Coming home @ 52* it was 184* Thermostat is what 2weeks old? I just don't get it.
It seems like that one cold morning changed it's value somehow.
Old Dec 15, 2013 | 09:01 PM
  #41
Mr.Nobody's Avatar
Mr.Nobody
Is 3-5 degrees a real problem? In the 40's-50's here now, and truck runs at 185- 187*f. These are the same temps I was getting on my trip from Montana in 20*f weather too. This T stat is only 2months old, are the quality of parts that hit or miss? All the big trucks seem to have removed their cold weather gear, but my little 6l seems to need extra pampering I guess?
Old Dec 16, 2013 | 05:04 AM
  #42
Rusty Axlerod
To be honest I don't know, but I think it might. Out of the box this thermostat was 191*. So that's 6* difference just 2 weeks after install. It was a rather inexpensive looking part (think I posted pictures earlier).
I do know my truck runs better the hotter it gets. A couple summers ago, before oil and EGR cooler change, temps would go way up. It seemed to run stronger the hotter it got but of course overheating isn't good either. I'd be happy if it stayed around 195*.
Old Dec 16, 2013 | 05:15 AM
  #43
dataman's Avatar
dataman
I just drove into work. It's a nice 15 degrees out there. Truck never made it over 186 and the oil over 191. I think this is just the nature of the beast.
I had a thought, haven't checked into it yet. I remember years ago (many years ago) that there used to be inline thermostats for the radiator hose. If they still made those why couldn't we just take the stock one out and put one in the upper radiator hose? The downside is that we have to cut the hose and it adds 2 more places for a leak to happen.
Old Dec 16, 2013 | 07:48 AM
  #44
Toreador_Diesel
As long as your oil temps reach a healthy 190, I would think you're good to go. My truck seems quite happy once the oil temps get to 180, but even better when the oil temps reach 190. Water temps rarely jump above 188 unless I'm on it.
Old Dec 16, 2013 | 08:06 AM
  #45
Per4mance's Avatar
Per4mance
I think it's the nature of the beast,there is a lot of coolant to warm up. That's a lot of calories to produce. I think there is more to this thou, the stat "should" keep the temps up, It does in my gasser and that has the extra big radiator for towing,it think it's the design of the stat myself....but I've been wrong before
