heater core bad?
Old Dec 9, 2013 | 08:54 AM
Kingkoopa's Avatar
Kingkoopa
heater core bad?
So tried to use the heater this weekend and nothing. Now every time I drive some where the passenger side fogs up and it smells of antifreeze in the cab. Any suggestions??
Old Dec 9, 2013 | 08:59 AM
osu711's Avatar
osu711
Sounds like your right, sounds like a heater core to me
Old Dec 9, 2013 | 12:48 PM
Kingkoopa's Avatar
Kingkoopa
Does anyone know of an easy bypass? or could i just the two hoses going to the core for a quick fix?
Old Dec 9, 2013 | 01:47 PM
osu711's Avatar
osu711
Im pretty sure you can couple the ends together, but you will have no heat. If i was you i would just change the core, pretty easy to do
Old Dec 9, 2013 | 02:38 PM
Kingkoopa's Avatar
Kingkoopa
i just ordered the core from rockauto.com but it will take a few days to get in. but i will have to couple the ends for now because each time i start the truck it is dumping a fair amount of antifreeze on the ground from the heater/ac drain hose when i turn it off. and im tried of my window fogging up.
PS it looks like there is a fog machine in the dashon the passengerside
Old Dec 9, 2013 | 04:06 PM
osu711's Avatar
osu711
lol, my core went out in summer so i didnt have that experiance.
Old Dec 10, 2013 | 10:47 AM
Kingkoopa's Avatar
Kingkoopa
simple fix a $3 5/8" spigot x spigot connected the inlet and outlet for the heater core. and no more foggy window
Old Dec 10, 2013 | 08:51 PM
oldbird1965's Avatar
oldbird1965
Don't you have to pull the dash to change the core?
Old Dec 11, 2013 | 08:06 AM
bigbrown1985's Avatar
bigbrown1985
Very simple to do I have done a couple, simply pull out the glove box and you will see about and 8x10 box with about 12 screws around it, pull those out and there it is it only cost about 26 bucks at napa or any parts house and its well worth that vs no heat!
Old Dec 11, 2013 | 08:38 AM
osu711's Avatar
osu711
Yes very easy, I have done a few myself. Just what ever you do DO NOT buy a core from Advanced, they last about 3 weeks before the solder joints come apart
midsouth
Nov 13, 2017 03:57 PM
dohc_chump
27
Sep 28, 2010 03:04 PM
73Riviera
Sep 8, 2006 02:08 PM
Tazzmann
Oct 11, 2005 08:38 PM
