7.3 fuel problem, maybe?
Old Dec 9, 2013 | 12:18 PM
john griffin's Avatar
john griffin
Gona try and suck all the fuel out of filter, it looks good but trying everything now.
Old Dec 9, 2013 | 04:34 PM
CampSpringsJohn's Avatar
CampSpringsJohn
If it cranks, and you have fuel, it should at the very least put out some white smoke.
Old Dec 9, 2013 | 04:38 PM
CampSpringsJohn
Are you getting the wait to start light?
Old Dec 10, 2013 | 12:00 PM
john griffin
Yes, I'm getting a WTS light and a little white smoke, got the block warmer plugged back in this morning, gona try again after I make sure no water is in fuel filter, also engine is making a knocking or rattling sound when trying to start.
Old Dec 10, 2013 | 12:20 PM
CrewCabLongbox's Avatar
CrewCabLongbox
I am looking at buying a 550 with the 7.3 and it actually had the same issue. Turned out to be the filters in the sending unit within the fuel tank. They get gummed up = no fuel. It sucks but you have to drop the tank to clean them. Check your air filter and fuel filter on top of the engine too. The sending unit is a last resort but might be the issue.
Old Dec 10, 2013 | 01:06 PM
john griffin
Thanks "Crewcab", the sock in the tank was changed last year, may have 5.000 miles sense. Don't drive it much in summer, I have a Jeep I like ti drive when warm, moving this weekend and need the truck.
Old Dec 10, 2013 | 09:05 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
One easy way to check the fuel system is to open the yellow fuel drain, with a hose on the pipe directed to a clean container, and key the pump on. You should get a healthy flow. A sputtering trickle would indicate a problem somewhere in the fuel system, be it pump or clogged strainers in the tank, whatever. If in doubt about the flow take a video so we can have a gander.
Old Dec 11, 2013 | 09:20 AM
john griffin
Thanks AAW, I'll give that a try today and report back.
powerfan99
17
Jan 1, 2013 09:43 AM
e.alleg
15
Mar 13, 2009 09:35 AM
marks500
13
Oct 21, 2008 10:46 PM
jamesmcowan
18
Nov 18, 2007 12:14 PM
jda
Feb 25, 2002 06:14 PM
