7.3 fuel problem, maybe?
Old Dec 8, 2013 | 03:52 PM
john griffin's Avatar
john griffin
Ok dumby here, I got a 1999 7.3, has about 200,000, ran great till three days ago. Went to move the truck and turned key on and waited for WTS light to go off, started engine as usual, let run for a little while, and put in Dr. the truck started moving then engine started to lope, pushed down on skinny pedal and it kept lopeing then died Turned key on again waited for light to go off, and it started and loped again and died. Engine is full of oil HPOP oil is close to one inch to the top, changed Cam sensor, already had one, still will not start. When I try to start it, it sounds like a gas V8 with some plug wires off and sorta has a knocking sound. Fuel filter is full, unpluged ICP, still no start, but has a little white smoke when it does fire.
Old Dec 8, 2013 | 03:57 PM
Pikachu's Avatar
Pikachu
How cold is it there? It sounds like bad glow plugs. Have you tried plugging in the engine block heater for a few hours and seeing if it will start after doing that?
EDIT: After re-reading your post I see it ran for a while, so may not be glow plugs, but still can't hurt to check the GPR and GPs.
Old Dec 8, 2013 | 03:58 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Did someone put gas in it?
Old Dec 8, 2013 | 04:34 PM
john griffin
Not glow plugs, because it was running fine, when the funny lopeing started and no on the gas in the tank, haven't fueled up for a week, hey thanks for the help. John
Old Dec 8, 2013 | 05:58 PM
trekbasso's Avatar
trekbasso
I know the other morning when mine had gelled fuel, it ran, but very bad. It does sound like you have a fuel pressure problem, for what ever reason. Try the red bottle Diesel Kleen, 911. Should take care of a gel issue.
Old Dec 8, 2013 | 06:02 PM
CampSpringsJohn
How cold did get at your place?
Old Dec 8, 2013 | 06:06 PM
trekbasso's Avatar
trekbasso
Wed morning it was -13 when it acted up. Had it plugged in overnight, also saw the problem on my fuel pressure gauge. People say keep the white bottle DK, or equivalent in the tank. I am a believer.
Old Dec 8, 2013 | 06:16 PM
CampSpringsJohn
I believe that untreated diesel can get cloudy around 35 degrees. Every place up here mix it with kerosene. I think I'm safe down to single digits. If it gets colder than that, I add some diesel fuel treatment to it. I've been told that places down south don't mix kerosene. I guess it's more expensive. I know the truckstops up here get calls when it gets cold and trucks from the south head this way.
Old Dec 8, 2013 | 06:28 PM
trekbasso's Avatar
trekbasso
Funny thing, I was planning on putting a couple of gallons in a jug outside, sort of a canary in the coal mine. Temps dropped more and faster than I expected. I have an inline filter pre pump, it was full of globs.
Old Dec 8, 2013 | 07:07 PM
john griffin
I am sorry I didn't say it was plugged in, in the shop, temp not a factor, I shouldn't have , but I sprayed a little starting fluid and it ran for about 5 seconds. then died. Oh the temp was in the 40s.
Old Dec 8, 2013 | 08:37 PM
arkredneck's Avatar
arkredneck
Starting fluid is really bad for these engines
Old Dec 9, 2013 | 05:35 AM
lartross's Avatar
lartross
...because the glow plugs will light it off at the wrong time...not good.
Old Dec 9, 2013 | 08:02 AM
john griffin
Starting fluid is not good for any engine, but sometime you try things to find problems.
Old Dec 9, 2013 | 09:19 AM
john griffin
Checked fuses and they are ok, fuel pump is running.
Old Dec 9, 2013 | 09:28 AM
eckart's Avatar
eckart
If your going to either the poor thing pull the leads off the gpr
