I just updated my dashboss version firmware to 1.69 I had to follow the manual update instructions due to virus protection not allowing the ***** to run. It went ok and I am running iPad app 1.95, my problem is it is not showing my full vin. And not all the allowable parameter picker categories are showing up. Anyone else have a similar issue? I have recently been having problems with my autoenginuity connecting to my truck. Funny thing is the scanguage2 is working fine
Here is a snapshot of the parameter picker screen.
I just did these same things, but I'm running a two year old iPad 2, and I have not updated to iOS 7. I have not noticed these issues, perhaps we can get some others to chime in? Did you contact dashboss? They respond well to emails.
It should at least show the first 3 digits of the VIN like 1FT
As for the gateway and Dashboss app. Do a level 1 reset, clear the app in background. Unplug the gateway and reconnect. Start engine, connect via bluetooth and start the app once bluetooth is connected.
Level 1 reset will reload all parameters.
Josh
You da man! It fixed it! Reset as you said. Now reading all parameters. Thanks!
All you guys using Dashboss, how often are you all having to do this? When it works, it is great, but it seems that I'm having more and more troubles getting the system to show more than N/A on all the perimeters. Any tips?
It has been about 9 months since it was updated, and I'm running 1.98 on the app. I was lead to believe that the app would instruct me when to update the gateway, by a previous post on a different thread. I guess I shall look into updating the gateway.
