Cab light bases cracked
Old Dec 6, 2013 | 10:43 AM
PlayersZ28's Avatar
PlayersZ28
Swapped out the orange covers for smoke ones on my truck and noticed that 4 out of 5 bases have cracks at the rear end of the lights. One screw would barely hold in as the plastic around the screw was all cracked which makes the hole larger.
Is this a common issue? Will Ford change them out under the ESP warranty?
Old Dec 6, 2013 | 12:46 PM
Hdslider's Avatar
Hdslider
I don't know if they will cover them.depends on what plan and your deductible.
As for breaking. I have seen a few busted up from going thru car washes.them big heavy leather strips beat the craps outta them.
Old Dec 6, 2013 | 01:20 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
You can only try with your dealership. I suspect they will say no (because they are susceptible to being hit by something), but it doesn't hurt to ask.
Old Dec 6, 2013 | 03:21 PM
PlayersZ28's Avatar
PlayersZ28
Thanks, I'll ask next time I'm there. As long as they don't start to leak I expect they're fine but if Ford won't replace them maybe I'll just buy a smoked set with bases.
Old Dec 7, 2013 | 05:48 AM
cabindoc's Avatar
cabindoc
I have bought several sets over the years and I have never seen where you can buy the base. I believe you will have to buy that from Ford. Meanwhile, a little silicone will help prevent water intrusion.
Old Dec 7, 2013 | 08:19 AM
PlayersZ28's Avatar
PlayersZ28
Pacer has a kit that includes the bases, wiring, LED's and lenses. Think I'll bring in a set of those and have a look at them.
Old Dec 11, 2013 | 04:21 PM
jsa3107's Avatar
jsa3107
Part number?
Or where to get them?
Old Dec 11, 2013 | 05:52 PM
PlayersZ28's Avatar
PlayersZ28
Originally Posted by jsa3107
Part number?
I'll have set tomorrow. I'll post up the pn and what they look like when I get them. Hoping they are good quality and the lenses fit the stock bases. Looks like the headliner has to come down to change the bases and don't want to have to do that right now.
Old Dec 12, 2013 | 11:35 AM
PlayersZ28's Avatar
PlayersZ28
Part number?
Got the lights in today from the warehouse. It's a complete kit with bases, wiring, switch & LED bulbs. Pacer pn 20-236S. Looks like the caps will fit the stock bases. Don't know what the stock wiring looks like behind the headliner to swap the bases. The lights will likely need splicing into the stock wiring.
http://www.summitracing.com/dom/part...236s/overview/
Old Dec 20, 2013 | 08:16 AM
PlayersZ28's Avatar
PlayersZ28
Stopped by my local Ford dealer and was told that the cab lights aren't covered by the extended warranty I have. This was the first thing I'd asked about on the warranty so not starting out well on what's covered for failure.
GarageSpec
Nov 4, 2011 09:09 PM
beefcake
Jul 7, 2011 11:31 AM
ltatkinson
6.7L Power Stroke Diesel
Feb 16, 2011 11:15 PM
97FRD1TN
Nov 4, 2009 01:23 PM
