Sponsored by: Real Truck
Engine block heater
Old Dec 6, 2013 | 06:01 AM
Dogmann's Avatar
Dogmann
Engine block heater
My 2008 V10 says on the window sticker that it came with a engine block heater.
Where would I locate the cord ? Anything special
I need to do? Or just plug it in!?? Thanks
Old Dec 6, 2013 | 06:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
There should be an extension cord looking thing around the front bumper.
Old Dec 6, 2013 | 06:14 AM
Dogmann's Avatar
Dogmann
I will look again. Didn't see it. Now , can I leave it plugged in for days if I'm not using my truck?
Old Dec 6, 2013 | 06:16 AM
Dogmann's Avatar
Dogmann
Also- do you guys use a standard heavy duty extension cord or does ford like you to use something they sell ?
Old Dec 6, 2013 | 07:16 AM
Will Bite's Avatar
Will Bite
You don't need to plug it in if your not using the truck. You probably don't need to use it.
Old Dec 6, 2013 | 09:03 AM
jstnromero's Avatar
jstnromero
If you do in fact need an engine block heater. 3-5 hours before you want to leave should be sufficient. Most people hook them up to a timer to come on a few hours before they leave first thing in the morning.
As far as the extension cord goes, just get a grounded Heavy duty outdoor rated cord and you should be fine.
Old Dec 6, 2013 | 01:42 PM
Dogwood36322's Avatar
Dogwood36322
Some trucks come with the block heater and not the cord. My 04 was like that from the factory.
Old Dec 6, 2013 | 03:20 PM
Forddiesel06's Avatar
Forddiesel06
Same here my 06 f-250 just has the block heater, you will need the plug wire harness and screw it into the block heater. Yes a heavy duty extention cord will do the job.....
Old Dec 6, 2013 | 03:28 PM
Pikachu's Avatar
Pikachu
Well that just seems pretty cheesy of Ford to do that.
Old Dec 6, 2013 | 04:30 PM
Dogmann's Avatar
Dogmann
Found it. Has the cord. Thanks
Old Dec 6, 2013 | 05:43 PM
Dogmann's Avatar
Dogmann
If the heater is plugged in -is it safe to start the truck while it's plugged in?
Old Dec 6, 2013 | 06:02 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
It won't hurt anything, it's just a hot loop of element inside the engine. It sits there just fine when the coolant gets into the 200s during normal op, just idling it shouldn't cause any problems. Just don't drive away with it plugged in.... did that once.
Old Dec 7, 2013 | 11:57 AM
fordman19762003's Avatar
fordman19762003
I know a lot of guys that do without any issues, but I wouldn't. I've been told that when the truck is running and the coolant is moving around you could get tiny air bubbles and if one of those bubbles settles around the heater element long enough it can burn it out.
I usually will plug my gas powered truck in a couple of hours before I leave or overnight if I need to leave early. My truck will start no problem no matter how cold it gets but it's easier on the engine and the engine warms up quicker if it's pre heated.
Old Dec 9, 2013 | 04:16 PM
ImaThorp's Avatar
ImaThorp
I use a little thermocube plug I got from the farm store. they sell them at home Depot too. It comes on around 35 and shuts off over 45
heres a link for the Home Depot one. Cadet Freezebuster FB3/TC3 Thermocube Ivory In-Line Limiting Plug-In Freeze Protection Thermostat-FB3 at The Home Depot
SteveEckart
Apr 1, 2018 08:32 AM
mudslide
Feb 25, 2009 09:19 AM
thegap1
Nov 9, 2008 09:02 PM
Big D
Dec 29, 2007 07:34 PM
1stFordF250
Escape & Escape Hybrid
Dec 5, 2005 10:55 PM
