Slave cylinder
Old Dec 5, 2013 | 02:17 PM
jmikeyj4's Avatar
jmikeyj4
Slave cylinder
hey guys having troubles with my 94 f-150 clutch, im having a hard time putting into gear 1,2 and reverse dont go in easily, 3 is fine and 4th sometimes grinds im hoping all have to do is bleed the slave cylinder. how do i go about finding the bleeder i believe i have a hydraulic clutch?
Old Dec 5, 2013 | 04:44 PM
broke vet's Avatar
broke vet
That year was equipped with a hydraulic clutch.
You will find an opening in the left side (referenced from the driver's seat) of the bellhousing with a hose leading into it and a threaded fitting above it. That fitting is the clutch bleeder.
Before you do that, though, check the plastic bushings inside the cab that connect the clutch master cylinder pushrod to the clutch pedal. They can crack and break and cause the same problem.
Old Dec 7, 2013 | 01:10 PM
jmikeyj4's Avatar
jmikeyj4
how do i go about bleeding it?
cwf081166
Mar 12, 2015 07:55 PM
hog hunter
Oct 30, 2006 04:51 PM
phil33
Jan 11, 2003 06:29 PM
ziller
May 29, 2002 09:43 PM
Roy Chris
Dec 16, 1999 06:06 PM
