Dual Exhaust...
Old 06-24-2003, 12:54 AM
lwkauble's Avatar
lwkauble
lwkauble is offline
Dual Exhaust...
I want to setup a dual exhaust along the line of what I have on my 99GT mustang. THe setup I have on there really rocks! I have Long tube headers with shorty X and magnaflow magnapack mufflers with 3.5" tips. Very agressive sound.
THe pipes and cat along with the muffler on this truck are completely rusted out.
Any ideas where I could get new Exhaust pipe? I'd like to run maybe 3" if I can... I was also thinking of using a set of headers and a modified Shorty H from one of my mustangs, and then adding a modified magnaflow magnapack catback setup (2.5" w/ 3.5 " tips) on there. I would need some extra pipe to do this. As mustangs are shorter than my truck. ( should measure while I'm thinking about it. Anyone know where I could get a set of Long Tube headers for a 360? Or maybe for 390 and also where I can get my hands on some heads for a 390. I'm dreaming of the possibilities now. Any comments or notes are welcome. Thanks!
Larry
Old 06-24-2003, 01:34 AM
fe8u's Avatar
fe8u
fe8u is offline
Dual Exhaust...
here's what I have in my '76 f-150 2wd. stock 360
Hedmen elite headders, they fit well, I believe the coating works also, no starter problems 1 1/2 yrs.
hedman universal x-over 2 1/2 ", that was tough to pipe for the muffler man! no room ,dual fuel tanks.
dual flowmaster 50 series muffler's, and 2 1/2" piping all the way out the back, under the bumber. I love this set up. For a stock engine this made a difference, I can't wait tell I finish my 428,he,he!
Old 06-24-2003, 09:30 AM
lwkauble's Avatar
lwkauble
lwkauble is offline
Dual Exhaust...
Hedman huh?
No cracks or anything?
no leaks?
what did you use to lock em down with?
stage 8 locking bolts?
Can you get the locking bolts for these heads?
I have stage 8 locking bolts on my mustang...
Thanks for the rest of the info.
Old 06-24-2003, 09:40 AM
lwkauble's Avatar
lwkauble
lwkauble is offline
Dual Exhaust...
I have one more question. Does anyone know if the bolt pattern on the 360 heads is the same in 75 as they were in 76?
Old 06-24-2003, 10:14 AM
Purely Ford's Avatar
Purely Ford
Purely Ford is offline
Dual Exhaust...
The bolt patterns for the exhaust manifolds on most FE heads are the same except for some high performance versions. The bolt pattern will be a vertical pattern (one over the other). They didn't make a high performance 360 that I am aware of.
Old 06-24-2003, 08:43 PM
fe8u's Avatar
fe8u
fe8u is offline
Dual Exhaust...
i used the bolts, and gasket that came with the headers, the flange they use is 3/8" thick so that helps. no gasket blow out ,no leaks, I've been happy with them.
Old 06-25-2003, 08:45 AM
73Custom's Avatar
73Custom
73Custom is offline
Dual Exhaust...
My '73 390 has Dynomax ceramic coated long tube headers and 2 1/4" duals out behind the rear tires, no crossover and just glass packs. You should check with the local muffler shop, they can probably custom make what you want for equal or cheaper cost than you buying and chopping your own exhaust.
Marty
Old 06-25-2003, 01:05 PM
460429_freak's Avatar
460429_freak
460429_freak is offline
Dual Exhaust...
yeah dual here from the manifold back with 12-18 glass pack cost $100- $150 my dad had 2 1/2 ex alumized exhaust with echo cannos done for $175
Old 06-27-2003, 11:45 AM
MustangGTvert's Avatar
MustangGTvert
MustangGTvert is offline
Dual Exhaust...
Marty
I'm sure you're quite correct in saying that they could do it cheaper. Fact is though, here in Ca, if that truck didn't come with dual exhaust, they won't make one for you, because there are rules against modifying exhaust. THat's why we do our own out here. when it comes time to smog the vehicle we just switch them out. I am also thinking of a custom exhaust.
Old 06-27-2003, 01:04 PM
Purely Ford
Dual Exhaust...
Don't the muffler shops in California install exhaust on any car that is built for racing? I have never heard of a muffler shop that refused to install some sort of special made exhaust for racing. They don't need to know or should even care that you may actually run it on the public streets if you say it is a car you race with.
As far as I know the only person responsible for breaking any emissions laws pertaining to modified equipment is the person who owns and operates the vehicle.
Old 07-02-2003, 08:45 AM
DONSRIDE's Avatar
DONSRIDE
DONSRIDE is offline
Dual Exhaust...
I HAVE A 77 F250 WITH A NEW CLEV.i WAS ALSO WONDERING ABOUT HEADERS. CALIF SMOG LAWS THATS OK????
