No Heat
Old Dec 4, 2013 | 08:00 PM
iwals's Avatar
iwals
No Heat
I'm trying to get the heater to work on my dad's 1992 F150. It's a 300 I-6 with factory air (the A/C has never worked though, but that's another story). The engine thermostat seems to work fine. It has two problems with the heat. One, the temperature **** isn't working the cable correctly. I removed the glove box to see the cable. Turning the **** doesn't move the cable; it seems to be in a bind, and I can't force it with a pair of pliers. Also, the vacuum line going to one of the actuators (is that the right term?) near the firewall under the hood has been chewed by a mouse. I found another vacuum actuator inside under the duct work. Since I don't have to worry about the A/C working on this, is there some way I could set it up where the temperature for the heater is just set to hot all the time? I tried to hold each of those two actuators in different positions, but it didn't make a difference. It blows plenty of air, and the air comes from where the selector is put, i.e. vent, floor, or defrost. It's just blowing lots of cold air.
Old Dec 4, 2013 | 08:07 PM
Jklnhyd's Avatar
Jklnhyd
You can cut off 1" of the vacuum tubing, and take it to the automotive parts near you and they can sell you the exact same thing by the foot. Tell them what you are doing and they can show you where the plastic slices are and you can just splice in the length you need.
As far as the binding goes, it may take a little patience or WD40 to free it up. My heater works great, too great, i definitely wouldnt want it on all the time.
abyars111
Dec 10, 2013 07:09 AM
FordOwnerJoey
Nov 29, 2011 09:02 AM
HENDEL JR
Dec 23, 2005 01:34 PM
John Thomas II
Sep 28, 2005 06:24 PM
David Hersman
Aerostar
Jan 27, 2005 09:59 AM
