Column shift to floor shift conversion
Old Jun 24, 2003 | 12:14 AM
momodoro's Avatar
momodoro
Unhappy Column shift to floor shift conversion
Help! I was wondering what I would need to do to convert my 1977 3-speed column shift to a floor shift. I am not real experienced at this but do know a few motorheads who could help once I know what to do. Or, tell me where I can find steering column parts for said vehicle. I only need the part where the shift lever connects to the column and it is NOT a part of the collar. Thanks.
Old Jun 24, 2003 | 09:02 AM
thelonerangerxlt's Avatar
thelonerangerxlt
The three-speed aftermarket shifter is relatively inexpensive and easy to install. Most auto parts stores carry the kits, and you can get them at places like Jegs, Summit, etc. The hardest part is locating and cutting the floorboard hole where the shifter will mount. After that, it's just a matter of bolting on the shifter and rods, and adjusting them.
You will probably have to go to a wrecking yard to find the stock shifter piece you are looking for.
Old Jun 24, 2003 | 12:23 PM
kaotikedge_111100's Avatar
kaotikedge_111100
I did this exact conversion on my 2wd supercab, it wasn't hard at all to do. The hardest part was getting the linkage perfect so she still shifted smooth. I bought the hurst indy truck three speed shifter from summit. I have tons of pics if you'd like to see them, but you'll have to send me a personal email if you'd like them. Good luck, it only took me about an hour to get it installed and then an hour of driving and shifting and adjusting afterwards, no biggie. Really improves the driveability of my truck too!!!
Old Jun 28, 2003 | 05:16 PM
Tubbieterror's Avatar
Tubbieterror
kaotike I am very interested in doing this. I'd like for you to send me the pics! thx
-Edit, use the system email function. If you post your email address the spammers get it. -Admin
Old Sep 4, 2009 | 09:09 PM
jeff1975's Avatar
jeff1975
This is perfect timing. I am just about to convert my column to floor on my 75 f100. Would you mind sharing the pics. My personal email is jcrealdeal@yahoo.com. I am also interested in knowing if you also looked at the mastercraft as I cant decide between that or indy. Thanks
Old Sep 4, 2009 | 09:20 PM
first today's Avatar
first today
Read this from beginning to end. This should help make a choice.
https://www.ford-trucks.com/forums/8...oor-shift.html
pukey
Dec 31, 2010 04:21 PM
nar&sfg
Jun 12, 2009 09:08 PM
Spocahp Anar
15
Sep 9, 2006 07:55 AM
John H III
Apr 29, 2006 11:13 PM
