Rear pinion is toast
12-03-2013, 10:26 PM
I'm looking to replace the whole rear end and am wondering if a rear axles from later models '05, '06 fit our trucks without adapters/modifications? Thanks in advance.
12-04-2013, 06:30 AM
Any ideas how late one could go into model year for a 10.5", 3:73, rear axle out of a SRW 250, 350? My truck is an E99.
12-04-2013, 10:04 AM
I think you'd be fine going up to a 2004, but 2005's went to the coil over front axle and I'm certain the wheel offset changed at that point.
12-04-2013, 10:32 AM
Quote:
Originally Posted by
clux
Thanks for the response, looking at an '04 right now.
12-04-2013, 01:41 PM
I'd check ABS wiring, too, in case that changed.
12-04-2013, 01:43 PM
04 will be the same.
If it's an F350, get the "blocks" and U-bolts, too, if you want to raise the rear an additional 1-1/2 inches. The shocks may also be longer-travel.
Pop
12-04-2013, 01:54 PM
SpringerPop
Pop
I got new bolts, can't I just use my old blocks? It was off an 250.
12-04-2013, 02:13 PM
Here is part of my ring gear. I believe this was the cause of my ABS light, sensor was a hacked up too.
12-04-2013, 02:19 PM
jhand124
Of course.
I failed to notice yours would already have the 3-1/2 inch blocks.
Pop
12-05-2013, 06:26 PM
New rear assembly is in, the truck is ready to go. After being sidelined for a month and a half gathering parts and finding a good engine to do the motor swap and now the rear end swap. ABS/speedo not functioning is also fixed with the rear end swap also. Finally
, I have been missing my truck...my pocket is a little lighter though
12-07-2013, 08:36 AM
Nice to have her all buttoned back up though. Congrats Jason.
12-07-2013, 05:51 PM
i went the 04 route only to find out, the threads are a fine pitch and the yoke would need to be changed, thus, having to "re-crush" a new crush sleeve. With that said, i found another 99-03 axle. The 04's collecting rust under my boat at the moment..
12-07-2013, 08:17 PM
I knew about the threads, I just got new lug nuts. The only other thing I had to do was get a different left side caliper.
grantpa
2009 - 2014 F150
10-19-2017 04:05 PM
GBeers
2004 - 2008 F150
07-24-2016 10:04 AM
strokingbeast
1999 to 2016 Super Duty
10-27-2010 09:05 PM
mizzitch
23
12-08-2008 03:23 PM
holla-if-ya-hear-me
01-25-2004 10:22 PM
