08 rear end queston
Oct 27, 2010 | 07:40 PM
08 rear end queston
does anyone know if a rear end out of a 01-04 swap parts with a 08. a buddy of mine snapped the rear axle shaft and is looking to buy another one. just wondering if we can pull one off a used truck.
Oct 27, 2010 | 08:03 PM
The wheel mounting surface dimentions are different. Also the spline count is different. The 99-04 had the same axle. 05+ is the newer style.
Oct 27, 2010 | 08:13 PM
so a rear axle shaft from the 05 and up will work?
Oct 27, 2010 | 08:16 PM
It should if the truck is a 08
Oct 27, 2010 | 08:28 PM
one more question do you know if anyone has a upgraded axle shaft. if he broke this one he will break another one
Oct 27, 2010 | 08:36 PM
Check with randy's ring and pinion. That would be my best guess on a place that would know or do a search. What is he doing to break the shafts?
Oct 27, 2010 | 08:40 PM
sand drags, drag racing, truck pulls, i guess hes seeing how much factory equipment will hold up to. lol
Oct 27, 2010 | 08:56 PM
so, basically he's putting too much torque to the pinion...
Oct 27, 2010 | 09:02 PM
Anything can be broken. It is not a common occurance that I know of though.
Oct 27, 2010 | 09:05 PM
yea lots of torque he has custom tuning from spartan and runs the 350 tune, with 40s
