2003 expedition door ajar problem
Old Dec 3, 2013 | 06:46 PM
texasman's Avatar
texasman
I'm have problems with the sensor on the doors. They keep saying that there's a door ajar and the ringing in the truck keeps going off non-stop. It's getting really agitating. Any ideas will help
-Thank you
Old Dec 3, 2013 | 07:15 PM
madsonp's Avatar
madsonp
Spray all your door latch mechanisms with a generous amount of WD-40. There's a switch on these that gets gunked up, the WD-40 helps clean them and loosen them up. This is a common problem.
Old Dec 3, 2013 | 08:12 PM
alloro's Avatar
alloro
Like the key in the ignition type of ringing? If so that would indicate the problem is with the driver's door ajar switch built into the latch mechanism. That would at least give you a starting point.
Old Dec 4, 2013 | 10:57 AM
Hamfisted's Avatar
Hamfisted
Door jamb switch.
Here's a link I posted on another site about replacing it:
Door Jamb Switch Replacement. The Airtex switch (Ford supplier...) is $23 from Rock Auto. It's almost always the driver's door switch, since that's the one that gets slammed all the time.
-Mike
Old Dec 4, 2013 | 09:38 PM
texasman's Avatar
texasman
Both. like the driving alarm when driving then key in the ignition ringing with key in but the door closed.
Old Dec 5, 2013 | 11:03 AM
alloro's Avatar
alloro
Then yeah, start with the driver's door latch and see if you can free up the switch there.
Old Dec 5, 2013 | 11:12 AM
madsonp's Avatar
madsonp
Did you try the WD-40 yet ?
dcara
Feb 21, 2008 05:59 PM
kenstacey
Mar 22, 2007 03:10 PM
flatheadv8
Nov 25, 2006 11:08 AM
Smoothbore
1997 - 2003 F150
Jun 1, 2006 11:45 PM
