Alternator?
Old Dec 3, 2013 | 01:49 PM
seventyseven250's Avatar
seventyseven250
Alternator?
Can anyone tell me how to diagnose what I think is a failing alternator?
Here are the symptoms:
- Hard starting in cold weather
- Battery not at full voltage when truck is parked (usually around 11.5-12 volts. I have been putting a charger on it some nights)
- Lights seem to dim when I've got accessories running, like heater fan, heated seats etc. Lights get brighter with engine RPM, like when pulling away from an intersection.
What's my next step to diagnose this? I did a search, and didn't see anything. My battery is probably still under warranty, so if that's the issue, it should be a free fix.
How hard is it to install an alternator in a 2005 with 5.4L engine? I'm moderatley handy, but haven't done this before.
Old Dec 3, 2013 | 02:54 PM
MarksA-C's Avatar
MarksA-C
Sounds like the same symptoms my truck had before the alternator went and the battery ended up being dead. I'd say replace that battery ASAP. A failing battery can overwork an alternator and end up being the cause of one failing.
If the alternator ends up being bad its a very simple replacement. Remove the intake hose thing and then its 3 bolts if I remember correctly.
Old Dec 4, 2013 | 11:23 AM
Tnelson82's Avatar
Tnelson82
x2 what he said.
Also check your battery terminals for corrosion and security first(just clean them up and tighten them down), but it sounds like a bad battery. Go to an auto parts store like autozone(or something similar) and have your battery tested. It's free. Replace the battery if its bad, if not move to the alternator. Get it done soon it is only getting colder outside and soon you will find yourself stuck and having to buy a battery instead of being not stuck and having to buy a battery,
Old Dec 4, 2013 | 01:37 PM
seventyseven250
Thanks guys, I will have the battery tested and see what comes out.
Tman_417
Jul 27, 2014 10:42 PM
johnarla
Mar 28, 2013 11:18 AM
crestfallinman
33
Mar 1, 2012 09:54 AM
tomtoc
Jul 13, 2007 12:55 PM
bcsbadboys
Oct 16, 2002 08:04 AM
