Quick brake question
Old Dec 2, 2013 | 10:07 PM
Scoop531's Avatar
Scoop531
Changed the rotors calipers pads and bearings on the front of my 78 f150 I noticed once done the rotors spin but not 100% freely they seem to be dragging. Is this common and will they adjust once used. I haven't done brakes in about 5 years so i can't remember if my last ones free spun after
Old Dec 2, 2013 | 10:19 PM
Blue and White's Avatar
Blue and White
It is common that they are a little tight with all new parts. The pads need to wear in a little and the calipers get centered. After a few hundred miles of stops, they should feel "normal". Cleaning of the caliper slide points by light flat file application and light grease application helps insure success.
Old Dec 2, 2013 | 10:35 PM
Scoop531's Avatar
Scoop531
That's what I thought I just wanted to make sure they barely make a full rotation before they stop
Old Dec 3, 2013 | 12:09 AM
jswartz84's Avatar
jswartz84
Mine also wear in after a couple hundred miles. Not just limited to this vehicle.
MadMedic20
Aug 6, 2010 09:38 AM
CdnFord Eh
Mar 9, 2007 01:33 AM
lukedraper
1978 - 1996 Big Bronco
Oct 23, 2005 11:18 AM
fordtrucklover94
Jan 19, 2005 02:25 PM
ddaa99
Apr 5, 2004 08:47 PM
