'95 E250 turn signal problem -
Old Dec 2, 2013 | 07:00 PM
Howard57's Avatar
Howard57
Hi, All four signals are out.
I only see one rectangular flasher. It clicks with emergency flashers.
My Haynes "80-96 Bronco and Pick-ups" book shows a round flasher on the fuse panel.
My panel has a place for that but it there is no flasher in place and there are NO Contacts in the slot!
Also shows fuse 7 for turn signal power.
I get no power in on fuse 7 slot, fuse looks OK.
I got a replacement, guy said it operates both emergency and turn signals.
I replaced but no change.
Anybody hear of this anomaly and know where I could find a schematic and fuse layout diagram to match my van better?
Thanks, Howard
Old Dec 3, 2013 | 06:42 AM
JWA's Avatar
JWA
If fuse #7 is suspected test it for continuity either with a DVM or test light---visual inspection of a blade fuse isn't reliable at all.
Something I find very useful for us DIY's is an OEM EVTM: Electrical Vaccum Troubleshooting Manual, aka Wiring Diagrams.
They are year/model specific for the most part, usually readily available on eBay for cheap: http://www.ebay.com/itm/1995-Ford-Econoline-Club-Wagon-150-250-350-wiring-diagram-electrical-manual-EVTM-/251391403233?pt=Motors_Manuals_Literature&hash=item3a881864e1&vxp=mtr
That one's a bit beat up but only $10, shipping included---good deal I think.
Hope this helps.
Old Dec 3, 2013 | 10:32 AM
blageurt's Avatar
blageurt
PM me your email and I can send you the diagram.....
Old Dec 3, 2013 | 01:18 PM
JWA's Avatar
JWA
Darn it---I keep forgetting you already have those on file----the easier and quicker way for sure!
Old Dec 3, 2013 | 11:41 PM
Howard57's Avatar
Howard57
Thanks, I'll take you up on that schematic offer.
I would really like to know what that fuse 7 is all about.
Meanwhile I went ahead and took stuff off to get the multi-function switch.
I took the 5 screws out and opened it up, and right away began to have second thoughts
because it looked a can of worms, but I was committed so...
Anyhow contact areas had a good bit of green
oxidation which I scraped and sanded off and smeared a little Vaseline on them.
By some small miracle I managed to get the thing back together correctly and it worked!!! I mean blinks too! and I am giving thanks
E30tdf
Electrical Systems/Wiring
May 17, 2014 12:55 AM
MD11Drvr
Feb 11, 2014 11:57 PM
Jordan M
Sep 7, 2010 06:47 PM
Taters
Jan 1, 2010 11:26 PM
88fordf150
Sep 15, 2005 10:11 AM
