1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Radiator hose
Old 12-02-2013, 04:58 PM
RobbD's Avatar
RobbD
RobbD is offline
Radiator hose
I need to replace my Radiator in my 2001 Expedition. Can I remoce the lower radiator hose quick connect without specials tool?
Old 12-02-2013, 06:19 PM
r2millers's Avatar
r2millers
r2millers is offline
Not that I know of. It's a real pain to remove. I used a aviation snips to cut off. Replaced hose and used a traditional hose clamp to repair.
Old 12-02-2013, 08:17 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
lower hose
cut it off
Old 12-03-2013, 10:04 AM
alloro's Avatar
alloro
alloro is online now
Received 4,216 Likes on 2,446 Posts
I need to replace my Radiator in my 2001 Expedition. Can I remove the lower radiator hose quick connect without specials tool?
There is a small metal tab that has to be bent out before you can rotate the connector and remove it. Once the tab is bent out, rotate the connector 45 degrees and pull HARD. It is a lot easier to remove if you remove the driver side wheel well skirt and attack the hose from there.
teamlx88
08-02-2010 10:48 AM
lilslammer
19
06-09-2010 02:18 PM
buggaboo
11-01-2008 11:13 PM
jimkari
07-18-2008 10:07 AM
kobrak12
12-04-2002 06:34 PM
Quick Reply: Radiator hose
