battery indicator light flashing
Old Dec 2, 2013 | 02:28 PM
VegiePower's Avatar
VegiePower
Hi folks. My battery indicator light is doing weird stuff. I have a secondary volt gauge that shows good voltage throughout. Checked posts and connections tight.
At idle the warning light is off. Under slow acceleration it starts to flash with the frequency increasing with greater acceleration until it finally goes solid with normal acceleration and highway speeds.
Any ideas?
Thanks
Old Dec 2, 2013 | 02:39 PM
Money-Pit's Avatar
Money-Pit
What type of volt gauge is it and what volt reading are you getting?
Usually the light comes on when you have under, or over voltage. Based on your description of how it's acting, I'm going to guess the alternator is over charging. That's only a guess though....based on my experience with various vehicles and off road construction equipment.
Old Dec 2, 2013 | 04:17 PM
mgraveman's Avatar
mgraveman
Any ideas?
Thanks
I saw this once before. It was an alternator where the commutator ring was worn through on part of it. At low speed the brush was able to keep contact enough to hold it on there. At high speed the ring was oval shaped and pushing the brush away enough that it couldn't keep good contact.
Pull the voltage regulator off the back and see if the brush is almost gone. If it is pull the alternator apart and see what the commutator ring looks like.
Old Dec 2, 2013 | 07:28 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Your alternator is going out, mine did the same thing! 14 volts but only 10-20 amps output, i verified with a dc clamp on meter...
BadDogKuzz
23
Apr 17, 2011 10:04 PM
2danglong
Mar 2, 2011 01:32 PM
MarkMoore
Dec 21, 2010 09:30 PM
badger2196
Jul 2, 2010 02:34 PM
illuzion
1978 - 1996 Big Bronco
Oct 14, 2005 07:49 AM
