From: Joliet illinois roughly 60 miles south of chicago
engine unknown,
Hi guys my 79 ford has a what i think to be either a 429 or possibly a 460,it used to have a 351m but it has since been swapped,without getting the numbers off the block the only other id was on the front part of the right valve cover if your facing the engine.it reads as follows.
C 91592AB C 60
2 R 16
abcdefeghijklm S 14
123 7
1234567890
I have no idea what any of it means but if you can help please do thanks...mike
I know the 385 series engines has 7. Does it have a seperate timing cover made of aluminum? And is the thermo stat housing attatch to the intake or the block?
It means your valve covers are from a 351M - perhaps they are original with the truck. In 25 years, a lot could have happened to the long block. Someone could have swapped in a 400 from a car - and moved a bunch of the original parts over.
