Noisy Lifter
Old Jun 21, 2003 | 07:04 PM
markallen's Avatar
markallen
Noisy Lifter
I saw a topic on this situation once and now I cannot find it. I have a noisy lifter and heard auto tranny fluid might help this. I tried off the shelf products and they did not work. How much ATF should I add to the engine oil to hopefully cure this problem? Thank You
Old Jun 22, 2003 | 05:44 PM
neverenough's Avatar
neverenough
Noisy Lifter
I've used Sea foam and it worked. If you have tried good products and they haven't worked, I would suspect it may be unrepairable with out going into the motor. It could be a worn cam lobe, a broken/ collapsed lifter, a bent push rod, plugged oil hole, or a bad rocker. Are you sure it is a bad lifter and not a leaking exhaust manifold or something?
Old Jun 27, 2003 | 06:06 AM
dusted800's Avatar
dusted800
Noisy Lifter
I had the same problem and thought it was a lifter also, it turned out to be a leaking exhaust manifold gasket. very common
