fast idle won't catch
Old Jun 23, 2003 | 08:49 PM
omni's Avatar
omni
I have a 1991 4.9, and when I start it cold, It acts like it's starving for fuel, some times it will catch and rev up to fast idle speed, but some times the tach flutters around 700 rpm then stalls, always starts fine on the second try. I though maybe I was trying to start it too quick, before the electric fuel pump primed up, but not sure if that is it, now I turn the key to the on position for a couple of seconds before I start, not sure if that helps sometimes it does sometimes it doesn't, is there a check valve in the gas line, that maybe letting gas siphon back to the tank, any clues? thanks:
Old Jun 24, 2003 | 10:48 AM
steve83's Avatar
steve83
Test the fuel pressure at the injector rail - your FP may be going bad. Mine did that and I found I only had ~7psi at startup. 35psi is MUCH better.
Old Jun 24, 2003 | 05:34 PM
omni's Avatar
omni
thanks steve I'll start there
krazeyelf
Jan 15, 2011 04:18 PM
Roller150
Aug 26, 2010 01:26 PM
aricanderson
15
Nov 29, 2009 01:17 PM
Polkat
Feb 14, 2006 01:17 AM
