cargo bed alignment?
Old Dec 1, 2013 | 10:06 PM
barkingmod's Avatar
barkingmod
I want to go look at a 1981 F150 2wd 6Cyl Auto. seller asking $1500 mileage assumed high.
looking at the tailgate the right side of the box looks much lower than the left, the top edge of the tailgate does not look aligned with the top edge of the front cargo wall under the rear window (again much lower at the right rear corner of the box). likewise looking a pics from the side the same corner looks low.
are there things I should be looking at given this appearance in pictures?
is this common? did someone dump a heavy load from the other side and overload just over the right rear wheel?
is it possible to look like this if the springs are bad on that side? bed alignment? new bushings? (I'm totally unfamiliar with the construction of this vehicle)
thanks so much
http://tinypic.com/r/11ihe7q/5
Old Dec 1, 2013 | 11:15 PM
ctubutis's Avatar
ctubutis
Could be a broken leaf spring on the RH side.
Old Dec 2, 2013 | 04:31 AM
bill06447's Avatar
bill06447
Where is it from? Here in the rust belt, frames and mounts are prone to rust. Many a truck broke its frame behind the cab where debris collects on the frame from the space between the cab and bed. ~Bill
Old Dec 2, 2013 | 08:28 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
Could be a few things. Definitely check the condition of your leaf spring. Even one broken leaf can make you lean the way you are describing.
-Junior
Old Dec 2, 2013 | 01:57 PM
barkingmod's Avatar
barkingmod
thanks for all input,
did everyone get to see the pic in the link? I may not have inserted it correctly. it is in the original post at the bottom.
thanks again
Old Dec 2, 2013 | 05:38 PM
Franklin2's Avatar
Franklin2
Broken spring is the most common cause. Essy fix but could be used to knock some money off the price. Find it and point it out.
JayP63
Aug 24, 2017 09:41 PM
pedrorairez
Sep 15, 2012 09:48 AM
94xlt4x4
33
Nov 9, 2009 08:24 PM
FordPowerStroke
Sep 10, 2005 12:15 AM
falcon50
Jul 21, 2004 03:20 PM
