Sponsored by: Real Truck
Dana 50 lockers
Old Jun 23, 2003 | 07:23 PM
99f350sd's Avatar
99f350sd
Dana 50 lockers
So who wants to know which lockers for their 99-01 SD with the dana 50????
After many hours of research I think I have some answers.
!st the lockright 2510 is the one that will work I'm told from a guy who sells em to SD owners and never got one back He says all D50's are the same.
2nd Of course the ARBD50.
And if you really want to you can find a detroit locker for it also.
Ask me Where........email
Just email me and I will be happy to answer your concerns..
I've made up my mind I'm going with the detroit soft locker in the rear and the lockright in the front......Finally
And did you know that if you have posi in the rear you can get a no slip locker from the lockright company that will just drop in to the posi case.....10.5 sterling..
Good locking
By the way powertrax who makes the lockright. well richmond now. doesn't even know that the 2510 will fit the newer D50's
Dick
Old Jun 23, 2003 | 09:30 PM
jetjock16's Avatar
jetjock16
Dana 50 lockers
how much for that front locker.. what are they charging..
Old Jun 23, 2003 | 09:41 PM
99f350sd's Avatar
99f350sd
Dana 50 lockers
$300 or so
Old Jun 24, 2003 | 07:33 AM
jetjock16's Avatar
jetjock16
Dana 50 lockers
I ordered one.. hope it works, thanks for the research.. been wanting one for awhile.. got stuck at the dunes 3 weeks back swore i wasnt going off pavement again till i had the locker up front... thanks
Rob.
Old Jun 24, 2003 | 08:57 AM
kehale's Avatar
kehale
Dana 50 lockers
ARB makes one, but....BE CAREFUL!
If you've ever had the diff apart you can see that the interenals are basically a Dana 44 (including inner splines!)
If you're hitting the mud or rocks, I'd stay with a limited slip (if they make one yet)
For sand or snow, you should be ok with a locker (ARB).
-T
Old Jun 24, 2003 | 05:48 PM
HeavyAssault's Avatar
HeavyAssault
Dana 50 lockers
I have come to the same conclusion for front lockers. After DAYS of research and asking questions the D50 has several options, you just got to ask for the right application.
Let us know how it goes.
Old Jun 24, 2003 | 06:14 PM
99f350sd's Avatar
99f350sd
Dana 50 lockers
ordered mine be here fri
Old Jun 24, 2003 | 10:19 PM
nafzimo's Avatar
nafzimo
Dana 50 lockers
Originally posted by 99f350sd
...And did you know that if you have posi in the rear you can get a no slip locker from the lockright company that will just drop in to the posi case.....10.5 sterling...
Do you mean the factory LS? How much? Can I change ratio (4x2)?
Old Jun 25, 2003 | 05:46 AM
99f350sd's Avatar
99f350sd
Dana 50 lockers
yes factory LS $450-$500 and What?
Old Jun 25, 2003 | 06:51 AM
nafzimo's Avatar
nafzimo
Dana 50 lockers
...and What?
Change ratio... ie: 3.73 to 4.10. I don't think it would matter.
Old Jun 25, 2003 | 01:30 PM
99f350sd's Avatar
99f350sd
Dana 50 lockers
sure you could go with 4:10 if you want. more$$$$$$$ alot more work even if you attempt it yourself.
Old Jun 26, 2003 | 01:58 AM
kehale's Avatar
kehale
Dana 50 lockers
Mine came with a front locker stock. DIdn't yours?
ok, I'm messing wit yaz.
Old Jun 26, 2003 | 05:48 AM
99f350sd's Avatar
99f350sd
Dana 50 lockers
Only in your dreams and mine.
The difference between a locked and unlocked truck!
one's a truck and ones a tractor
one you can get yer keys out of the ignition, the other you wish you could
Old Jun 28, 2003 | 03:18 PM
99f350sd's Avatar
99f350sd
Dana 50 lockers
installed the rear detroit today. sat What a job not for the inexperienced!! The bearings were trashed so I had to get some new units not bad $100.00. oil was 50.00 anyhow just waiting for the silicone to dry before I put the oil in then maybe i'll tackle the front lockright tonight or tomorrow..
Old Jun 28, 2003 | 03:24 PM
because's Avatar
because
Dana 50 lockers
99f350sd whick lockers did you go with? I'm thinking of putting in a rear now and the front in a couple months but i can't find a front. i dont want to spend a ton a money like the air ones.
