Sponsored by: Real Truck
Dana 50 lockers
Old Jun 29, 2003 | 11:23 PM
  #31
kehale's Avatar
kehale
Dana 50 lockers
The only locker for the D50 is the ARB Air Locker.
Even then, the axles strength is in question.
It's basically a D44 inside.
-T
Old Jun 30, 2003 | 12:09 AM
  #32
99f350sd's Avatar
99f350sd
Dana 50 lockers
I know you read the whole thead so why do you still believe that?
Do you know something we don't.
Old Jun 30, 2003 | 12:43 AM
  #33
kehale's Avatar
kehale
Dana 50 lockers
You go ahead and put a non-selective locker in your front D50 on a superduty and see how long it lasts.
I've seriously lost count of how many I've seen broken.
Not to say that if you run in sand you're going to blow up your case, but....mud, dirt/rocks....you write the check.
With an ARB, you can lock when you NEED to or leave off and still have 3 wheel (or 2 wheel) drive (depending on your rear diff situation)
Your money, your truck.
Me, I'm open in the front. Care to guess why?
-T
Old Jun 30, 2003 | 06:03 AM
  #34
99f350sd's Avatar
99f350sd
Dana 50 lockers
Gonna do a detroit in the front. I drive easy anyway. Main reason is for plowing....Thanks for your input.
Dick
Old Jun 30, 2003 | 10:02 AM
  #35
kehale's Avatar
kehale
Dana 50 lockers
Dick
I'm not trying to be mean, but...
good luck turning. (use the plow to turn)
As you'll be under power when you plow, your truck will have the uncanny desire to go straight.
Let us know how it works out.
-T
PS: A better solution would be to remain open in the front and add a bunch of weight just behind the cab (sand ballast)
Old Jun 30, 2003 | 12:26 PM
  #36
RRMike's Avatar
RRMike
Dana 50 lockers
..99..,
I am glad you took my comments for what they were. I just wanted to make sure you were aware of some of the drawbacks of the front locker and it seems you are.
Good luck.
Old Jun 30, 2003 | 01:06 PM
  #37
jetjock16's Avatar
jetjock16
Dana 50 lockers
ill have my powertrax locker in front by the end of the week, ill tell ya'll how it works on hard dirt, loose gravel and sand dunes.. as ill be testing it on all three by the end of the weekend.. im not to worried about all the above described problems as ive only got about 15 miles of use on my front diff and 35K miles on the truck.. ie.. i only use 4x4 when its about to go into the sand... or in any other surface i wait till the Auburn cant get me any further..than i pull myself out with the 4x4... only hunting, fishing, and camping and dunes... get me to engauge those hubs... i dont 4x4 for sport... well i do have great times hunting and fishing getting to places no man has gone before..he he.. my point is im not out there bashing this thing.. i use my 4x4 as an emergency out.. ive never needed it on any surface but sand since i installed the Auburn... i am concerned about snow.. as niether the Auburn or the Powetrax up front are going to be friendly on ice..(no Lateral traction).. but i wont use the 4x4 then either.. it actually degrades steering and braking control even with an open diff...... i can see it now though... ill be on a SLOPE in snow and my auburn rear end will only slide down the slope.. towards a ditch or cliff? and if i engauge the front locker it will slip down the slop also.. id be screwed... then again lock one hub? thatll do it!
Jetjock16
Old Jun 30, 2003 | 03:26 PM
  #38
99f350sd's Avatar
99f350sd
Dana 50 lockers
I just talked to my supplier he said he made a booboo when he said he could get a detroit to fit in the front of my truck. Oh well so much for that. I'm back to the lockright. As soon as I get my tools for the ball joints....
Kehale: QUOTE I'm not trying to be mean, but...
Iv'e been plowing for 5 years with lockers in both ends. In no way is it objectionable. In fact I never get stuck and I can plow where no one else can, Its totally awsome. As far as steering control etc. I don't use 4wd over 20 mph and steering while plowing is no different with lockers. I live in Vt up near the canadian border. My driveway is the steepest driveway in town.
Just to haul a load up it in the summer requires a front locker.. I think I know exactly what i'm doing..Thanks for the concern.
Dick
Old Jun 30, 2003 | 03:35 PM
  #39
kehale's Avatar
kehale
Dana 50 lockers
Dick
You got it.
I'm not plow expert. (Calfornia...snow? uh...)
-T
SuperDutyScaler
Dec 28, 2011 02:52 PM
FordMuddin'
Offroad & 4x4
Mar 9, 2011 04:49 PM
profro
Sep 23, 2010 02:30 PM
fordinmudd
Offroad & 4x4
64
Mar 4, 2007 09:42 AM
88B_RONC
Offroad & 4x4
Nov 14, 2002 07:27 PM
