what is a Powertrax Lock Right Locker ?
Nope its a full on locker . The only major difference between it and say the detroit locker is that the detroit replaces the entire carrier whereas the lockright replaces only the spider gear, unless you are running some power and big tires and are wheeling it hard this i think is the way to go, *** you can beat on them fairly hard (but again if you're plannin on abusin it with big tires and the power to spin them the detroit/full carrier replacement types are the way to go).
Yeah i have lockrights front and rear (dana 60 front 10.25 rear) and i'm running 35x16 boggers and its for comp. mud bogs only and i have yet to be let down.
Good example of this, last bog of the season the drivers front axles (yokes blew apart on the axle/stub from fatique cracks) and thus no drivers side front tire stops pulling, but the other side kept on going no problems.
I believe so Kubota. I installed one recently on my Dana 44 TTB(can't find a single axle yet) and it would make a very loud popping noise about once every revolution of the tire. I left the thrust washers out to make it fit maybe that would be the problem??? Has anyone else had that happen to them?
> from what i understand lockers are bad on ice and real bad on ice and snow roads.
If you drive fast without any thought, yea, they are deadly, especially down hill on a curve. Then again, many people drive with welded rear ends in the winter, so I would say it is mostly up to driver input and speed.
I had my AWD Aerostar's L/S send me off the road during a snow storm when I least expected and I could not recover in time because I had an automatic. If I had a clutch it would have been only a small problem. Though I did manage to get out of the corn field before I sunk window deep into the snow.
If I had a standard shift vehicle and was in 4x4 on ice with a locker, I would just go slower then normal and not worry about it.
Man I am so tired of hearing how bad lockers are on ice, and snow. Obviously the people stating that haven't actually used one, and compared to a limited slip NO DANG DIFFERENCE on limited traction surfaces unless one tire is on solid ground, and the other is on ice then the locker will move you, and the posi won't. Lockers are absolutly no worse on ice than anything else nothing works good on ice but a locker will get you out were a limited slip clutch type posi will leave you stranded, and an open won't even think about.
I have run lockers in both 2wd, and 4wd, and didn't have any problems, must be the drivers I guess.
Originally Posted by KubotaOrange76
they are activated the same way a detroit is correct??? when torque is applied, they lock both tires...right??
They are only fully locked when there is applied power to the locker, as in the lockright the springs hold the 2 halves apart, and where the crosspin goes through the locker, the hole in the locker is a tapered hole shape (both front and rear of the the hole for reversing and going forward)so that when power is applied either front or backwards, the crosspin forces the halves of the lockright togetherthus fully engaging the locker.
The only reson why it disengages around corners is that 90% of people let of the gas, or at least don't apply any additional power, then the halves of the lock right disengage and stay disengaged till there is equal wheel speed and power is applied.
