78 f100 lift
78 f100 lift
I've got my Grandpa's 78 f100 custom 2wd that I am going to fix up and put a small lift on. I am going to add a leaf in the rear which will provide 2 inches of lift and put new coil springs in the front that will ad 4 inches of lift so it is level with the rear end. Will this set up work? Will I need to do something to the beams or arms? If so please explain. The truck has a 300 straight six with 3 on the tree and is not a daily driver. Thanks
There is a front end alignment shop here, near town, that has the machine/ tool to bend those I-beams, to correct the camber.
Check around your home town for an alignment shop, old school shop, that might have one, they might be willing to do this alignment correction.
The tracking arm will need to be replaced or the tracking arm bracket (longer one needs to be installed). The off road shop carry them.
Or try a junkyard for some of the parts.
On a 4WD, the straight axle floats free and is triangulated by the radius arms and located by a track bar.
I bet your 4" lift kit coils are for a 4x4, not a 2wd. Oh they might fit, but your camber will be WAY OUT, to the point it will not be a driver at all.
Best and cheapest thing to do it a 2" or 3" body lift. Unless you can afford to do it properly and safely.
That white truck does not have stock front suspension, at all.
HIO covered the rest.
I also wanted to lift my 2wd truck for bigger tyres. Decided on a suspension lift. But doing it right is quite expensive. And for me, when it comes to important parts like suspension and steering cutting corners is not the best option. Sorry i dont have a answer for your question. But just bare in mind that if you do have slight negative camber it might influence your tires running on down more on the sides. So like the others said dont try the cheap way. I am leaning more to the bodylift now to accommodate for the bigger tyres.
